- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
The Template-hosting S3 Region parameter must match exactly the AWS region in which you try to deploy. If the region does not match, the deployment does not succeed.
Keep the default settings for the parameters labeled Quick Start S3 bucket name, Quick Start S3 bucket Region, and Quick Start S3 key prefix. If these input parameters are altered, the deployment does not succeed.
Parameter label (name) |
Template |
Default value |
Description |
Availability Zones |
Choose up to three Availability Zones to use for the VPC subnets. |
Number of Availability Zones |
Choose the number of Availability Zones to use in the VPC. For a new VPC, this must match the number you set using the Availability Zones parameter. For an existing VPC, you can set two or three Availability Zones. |
Deploy Bastion host |
Deploy a Bastion host inside the public subnet. |
CIDR for bastion's ingress for SSH traffic |
Ingress Security Group CIDR (for SSH). Configure this parameter only if you set the Deploy Bastion host parameter to
true . Set to x.x.x.x/32 to allow one specific IP address access, 0.0.0.0/0 to allow all IP addresses access, or another CIDR range.
Template |
Default value |
Description |
VPC CIDR |
VPC CIDR block. Example:
x.y.0.0/16 , x.y.z.0/24 .
VPC ID |
ID of the existing VPC. |
Public subnet IDs |
List of public subnet IDs where the internet-facing Load Balancer and the Bastion host will be deployed. |
Private subnet IDs |
List of private subnet IDs. |
Parameter label (name) | Template |
Default value |
Description |
Server instance type |
Choose the node type for the Server node instances. |
Server instance count |
Choose the number of nodes to deploy as Server node instances. |
Agent instance type |
Choose the node type for the Agent node instances. |
Agent instance count |
Choose the number of nodes to deploy as Agent node instances. |
GPU agent instance type |
Choose the node type for the GPU Agent node instance. |
Task Mining agent instance type |
Choose the node type for the Task Mining Agent node instance. |
AS Robots agent instance type |
Choose the node type for the AS Robots Agent node instance. |
AS Robots agent instance count |
Choose the number of nodes to deploy as AS Robots Agent node instances. |
Template |
Default value |
Description |
Instance key pair |
Existing key pair to connect to virtual machine (VM) instances. |
Instance AMI ID |
AMI ID to use for the creation of the EC2 instances of the cluster. When the AMI ID is not specified, the default version deployed is RHEL 8.3 for non GPU VM and RHEL 8.2 for GPU VM. |
GPU instance AMI ID |
AMI ID to use for the creation of the GPU-enabled EC2 instance. |
IAM Role ARN |
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment. |
IAM Role name |
Name of a pre-deployed IAM Role with sufficient permissions for the deployment |
Template |
Default value |
Description |
Enable cluster backup |
Enable the cluster backup. |
Use a shared bucket for external storage |
| false | Enable a shared bucket across products. If you choose true , Process Mining and Data Service require a dedicated bucket each.
Load Balancer |
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you must configure the TLS certificates manually post deployment. |
Ingress Security Group CIDR (for https) |
Ingress Security Group CIDR (for HTTPS). Set the CIDR to allow access to Automation Suite. Set the CIDR to
Perform Installation |
Perform the Automation Suite installation. |
Automation Suite Version |
e.g.
23.10.0 |
Automation Suite version to install. |
Installer download URL |
Custom URL for installer download. Leave empty to use the UiPath version. |
Add GPU-enabled VMs |
| false | Choose true to add a GPU-enabled VM to the deployment.
Extra configuration keys |
Extra configuration keys to add to the cluster configuration. |
Validity of the self-signed certificate |
| Validity, in days, of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC. |
Disable presigned URL |
Enable or disable objectstore access via pre-signed URLs. |
Template |
Default value |
Description |
Service install flags (multiple) |
Choose if a specific service is installed in the cluster. |
Parameter label |
Template |
Default value |
Description |
External Registry Fully Qualified Domain Name |
| Blank string | External registry Fully Qualified Domain Name |
External Registry user name |
| Blank string | External registry username |
External Registry password |
| Blank string | External registry password |
Template |
Default value |
Description |
Connect AI Center to an external Orchestrator |
Register AI Center to an external Orchestrator. |
Orchestrator URL |
URL of the external Orchestrator. Example:
https://my-orchestrator.net |
Identity URL |
URL of the Identity server used. Example:
https://my-orchestrator.net/identity |
Base64-encoded Orchestrator certificate |
Base64-encoded Orchestrator certificate string. Example:
UExBQ0VIT0xERVI= |
Base64-encoded Identity certificate |
Base64-encoded Identity certificate string. Example:
UExBQ0VIT0xERVI= |
Templates |
Default value |
Description |
Hosting FQDN |
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the of
ID of Route 53 hosted zone parameter.
ID of Amazon Route 53-hosted zone |
Enter the ID of the Route 53-hosted zone or leave blank. For details, see Valid domain name. If you deploy to AWS GovCloud, you must associate the Route 53 resource for your custom domain with the existing VPC. |
ARN of the ACM-hosted certificate |
ARN of the certificate present in the ACM (Amazon Certificate Manager) to use with the ALB. This parameter is mandatory if you deploy to AWS GovCloud. |
Use Internal Load Balancer |
Choose if you want to use an internal load balancer. |
Template |
Default value |
Description |
Engine of SQL Server deployed on RDS |
Choose the RDS Microsoft SQL engine. |
Version of SQL Server deployed on Amazon RDS |
Choose the RDS Microsoft SQL version. |
AWS KMS Key Id used to encrypt Amazon RDS storage |
KMS Key ID to use for the encryption of the RDS storage. |
Parameter label (name) | Template | Default value | Description |
Template-hosting S3 bucket |
| uipath-s3-quickstart |
You must not change the value. |
Template folder |
Template-hosting S3 Region |
Must match the region where you deploy the resources in AWS. For example, if you want to deploy in
us-east-1 , select us-east-1 .
- Table 1. Availability Zone configuration
- Table 2. Network configuration
- Table 3. Automation Suite node configuration
- Table 4. Automation Suite instance configuration
- Table 5. Automation Suite deployment configuration
- Table 6. Automation Suite service configuration
- Table 7: Automation Suite external registry configuration
- Table 8. Automation Suite external Orchestrator configuration
- Table 9. DNS or SSL configuration
- Table 10. Amazon RDS configuration
- Table 11. Partner Solution S3 bucket configuration
