Last updated Oct 13, 2025
Failure after certificate update
This issue occurs when the certificate update step fails internally. You may not able to access Automation Suite or Orchestrator.
Error
Solution
  1. Run the following commands from any of the server node:
    export KUBECONFIG=/etc/rancher/rke2/rke2.yaml
    export PATH=$PATH:/var/lib/rancher/rke2/bin
    kubectl -n uipath rollout restart deploymentsexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml
  2. Wait for the previous command to succeed and then run the following command to verify the status of previous command.
    deployments=$(kubectl -n uipath get deployment -o name)
    for i in $deployments;
    do
    kubectl -n uipath rollout status "$i" -w --timeout=600s;
    if [[ "$?" -ne 0 ]];
    then
        echo "$i deployment failed in namespace uipath."
    fi
    done
    echo "All deployments are succeeded in namespace uipath"deployments=$(kubectl -n uipath get deployment -o name)
    do
    then
    fi
    done
Once the previous command has finished executing, you should able to access Automation Suite and Orchestrator.
  • Description
  • Error
  • Solution
