- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
The following diagram depicts a regular Active/Active deployment of Automation Suite:
Hardware |
Requirements |
Global Traffic Manager (GTM) | Distributes traffic
to your Automation Suite multi-site deployment. The service must
be highly available and immune to any deployment site.
Additionally, the GTM must be able to configure the health check
to isolate the faulty site quickly. The GTM is not mandatory but
is recommended for a quick switchover.
When configuring the
Global Traffic Manager (GTM) for Active/Passive or
Active/Active deployments, make sure to use
/orchestrator_/api/status as the health
endpoint. This is critical for effective disaster recovery
management.
Load balancer | Every site needs a
local load balancer that can load-balance the traffic to any
node configured in the same site.
For more details, see Configuring the load balancer. |
Node |
Every site must have at least three servers, whereas agent nodes are optional. The exact number of machines depends on the machine size and overall capacity requirements. You do not need to bring the same set of nodes to each cluster. In the case of Active/Active configurations, the size of the secondary cluster can be smaller, considering that you may install only a few products. For more details, see Automation Suite Install Sizing Calculator. |
SQL database |
An external SQL server is required to store the data. For disaster recovery, you need Always On Availability Groups with a primary SQL server in Site 1 and at least one secondary physically SQL Server located in Site 2 with data sync enabled. There is also a SQL listener deployed on top of the SQL server. Both clusters are configured to use the address of the same listener. |
Objectstore |
Any files or packages uploaded to products are stored in the objectstore. For greater resilience to failure, Automation Suite deployments require an external objectstore. For effective disaster recovery, two objectstore instances are required; one instance must be situated in each data center. At any given time, only one objectstore instance must be actively used for reading and writing by both clusters. This process must be complemented by asynchronous replication to the secondary instance. |
High Availability Add-on |
For Active/Active, High Availability Add-on must be external to Automation Suite and must be installed on separate machines. A minimum of three nodes are required for both High Availability Add-on instances in each data center, configured in different clusters and synchronized (CRDB replication). To install High Availability Add-on, see the High Availability Add-on Installation Guide. For Active/Passive, High Availability Add-on is installed within the Automation Suite cluster. However, you must enable it on both clusters by providing the HAA license. For more details, see Enabling Redis High Availability Add-On for the cluster. |
Elasticsearch (optional) |
Elasticsearch is required to send the robot logs. You can configure the Elasticsearch cross-site replication as described by Elasticsearch. |
