- Overview
- Requirements
- Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring SQL databases
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Aug 11, 2025
DescriptionPods using LH volume are stuck in Init:0/X (where X is an integer representing the number of containers), and the kubectl describe command on the pod returns MapVolume.MapPodDevice failed for volume in events.
To fix this issue, run the following command:
for podPv in $(kubectl get events -A -o json | jq -r '.items[] | select(.reason == "FailedMapVolume" and .involvedObject.kind == "Pod" and (.message | contains("MapVolume.MapPodDevice failed for volume") and contains("Could not mount \"/dev/longhorn"))) | .involvedObject.namespace + "=" + .involvedObject.name + "=" + (.message | match("(pvc-[0-9a-z-]+)").captures[0].string )') ; do
echo "Found 'FailedMapVolume' error: '${podPv}'"
NS=$(echo "${podPv}" | cut -d'=' -f1)
POD=$(echo "${podPv}" | cut -d'=' -f2)
PV=$(echo "${podPv}" | cut -d'=' -f3)
[[ -z "${NS}" ]] && echo "Could not extract namespace for error: '${podPv}'" && continue
[[ -z "${POD}" ]] && echo "Could not extract pod name for error: '${podPv}'" && continue
[[ -z "${PV}" ]] && echo "Could not extract Persistent Volume for error: '${podPv}'" && continue
controller_data=$(kubectl -n "${NS}" get po "${POD}" -o json | jq -r '[.metadata.ownerReferences[] | select(.controller==true)][0] | .kind + "=" + .name')
[[ -z "$controller_data" ]] && echo "Could not determine owner for pod: ${POD} in namespace: ${NS}" && continue
CONTROLLER_KIND=$(echo "${controller_data}" | cut -d'=' -f1)
[[ -z "${CONTROLLER_KIND}" ]] && echo "Could not extract controller kind for pod: '${POD}' in namespace: '${NS}' && continue
CONTROLLER_NAME=$(echo "${controller_data}" | cut -d'=' -f2)
[[ -z "${CONTROLLER_NAME}" ]] && echo "Could not extract controller name for pod: '${POD}' in namespace: '${NS}' && continue
if [[ $CONTROLLER_KIND == "ReplicaSet" ]]
then
controller_data=$(kubectl -n "${NS}" get "${CONTROLLER_KIND}" "${CONTROLLER_NAME}" -o json | jq -r '[.metadata.ownerReferences[] | select(.controller==true)][0] | .kind + "=" + .name')
[[ -z "${CONTROLLER_KIND}" ]] && echo "Could not extract controller kind(from rs) for pod: '${POD}' in namespace: '${NS}'" && continue
[[ -z "${CONTROLLER_NAME}" ]] && echo "Could not extract controller name(from rs) for pod: '${POD}' in namespace: '${NS}'" && continue
fi
org_replicas=$(kubectl -n "${NS}" get "$CONTROLLER_KIND" "$CONTROLLER_NAME" -o json | jq -r '.status.replicas')
echo "Scaling down ${CONTROLLER_KIND}/${CONTROLLER_NAME}"
kubectl -n "${NS}" patch "$CONTROLLER_KIND" "${CONTROLLER_NAME}" -p "{\"spec\":{\"replicas\":0}}"
if kubectl -n "${NS}" get pod "${POD}" ; then
kubectl -n "${NS}" wait --for=delete pod "${POD}" --timeout=300s
fi
if kubectl get volumeattachment | grep -q "${PV}"; then
volumeattachment_id=$(kubectl get volumeattachment | grep "${PV}" | awk '{print $1}')
kubectl delete volumeattachment ${volumeattachment_id}
fi
[[ -z "$org_replicas" || "${org_replicas}" -eq 0 ]] && org_replicas=1
echo "Scaling up ${CONTROLLER_KIND}/${CONTROLLER_NAME}"
kubectl -n "${NS}" patch "$CONTROLLER_KIND" "${CONTROLLER_NAME}" -p "{\"spec\":{\"replicas\":${org_replicas}}}"
done
then
fi
fi
fi
done
