- Overview
- Requirements
- Deployment templates
- Manual: Preparing the installation- Manual: Preparing the installation
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade- Step 1: Moving the Identity organization data from standalone to Automation Suite
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Product-specific configuration- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting- How to troubleshoot services during installation
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
To perform an Automation Suite upgrade, you must put the cluster in maintenance mode. Maintenance mode causes downtime during the entire upgrade process, and your business automation is suspended during this time.
It is strongly recommended to create a backup of the cluster and the SQL database before the upgrade. This is to ensure you can restore the cluster if something goes wrong during the upgrade operation.
Cluster data is backed up on the NFS server. Make sure to configure the NFS server before proceeding.
You must configure the backup after disabling the maintenance mode to ensure that all transactions are completed.
Putting the cluster in maintenance mode shuts down the ingress controller and all the UiPath® services, blocking all the incoming traffic to the Automation Suite cluster.
To configure the backup, take the following steps:
Once the backup is created, continue with the following steps.
uipathctl command from the target version directory when you upgrade from 23.10.0 or later versions.
                     cluster_config.json file as described in Updating the cluster configuration.
                        cd /opt/UiPathAutomationSuite/latest/installer
./install-uipath.sh --upgrade -i cluster_config.json -o ./output.json -k --accept-license-agreementcd /opt/UiPathAutomationSuite/latest/installer
./install-uipath.sh --upgrade -i cluster_config.json -o ./output.json -k --accept-license-agreement-
                           Running the previous command on the primary server node copies the installer andcluster_config.jsonto the/opt/UiPathAutomationSuite/<version>/installerdefault location and upgrades the infrastructure on all the machines.
                           The/opt/UiPathAutomationSuite/<version>default location must have at least 5 GB available across all nodes.
                           To change the default location, update the following environment variable with the desired location. Make sure that the location is available on all the nodes and has the required permissions to run the upgrade. export INSTALLER_DIRECTORY=/path/to/copy/installerexport INSTALLER_DIRECTORY=/path/to/copy/installer
                           After executing the previous command and running the upgrade, the installer is copied to the/path/to/copy/installer/<version>/installerlocation.versionis replaced with the version of the installer that you execute.
Troubleshooting
                           The upgrade logs on the primary server are available in the/opt/UiPathAutomationSuite/latest/installer/upgrade-logsdefault location, unless you explicitly used a custom location for the installer.
                           On all the other nodes, the logs are available in the/opt/UiPathAutomationSuite/<version>/installer/upgrade-logsdefault location, unless you explicitly changed this location via theINSTALLER_DIRECTORYvariable.
