- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Setting up the external NFS server
- Additional configuration
- Restoring the backup
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Oct 13, 2025
Important:
UiPath® does not provide any specific steps to repave or update the NFS server.
Before updating the NFS server, make sure the backup is disabled. For instructions, see .
Guidelines
It is good practice to back up the disk attached to the NFS server where you create the backup. You can find this information defined as the
nfs.mountpoint
key in thebackup.json
file. -
To repave the NFS server, take the following steps:
- Mount the backup disk on the newly repaved machine on the same mount point as defined by the
nfs.mountpoint
file. - Update the NFS endpoint of the new NFS server defined as
nfs.endpoint
inbackup.json
. - After repaving the NFS server, make sure you have followed the Setting up the external NFS server guidance.
Once the update to NFS server is complete, it is recommended to reboot the machine. Also make sure to enable the backup on cluster. For instructions, see .
Adding a new node to the cluster
To add a new node to the cluster, re-run the following steps:
- Add the FQDN or the IP address of the new node to the allowlist of the NFS server. For instructions, see Allowing NFS mount path access to all backup and restore nodes.
- Enable the backup on the new node post-installation. For instructions, see Configuring the cluster snapshot backup.
