- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
This step is needed only for offline installations that use an in-cluster registry. You can skip this step if you perform an offline installation that uses an external OCI-compliant registry, or an online installation.
/uipath mount point.
The temporary Docker registry is only required during installation or upgrade. Once the installation or upgrade is successful, the temporary registry is no longer needed and should be uninstalled.
To set up the temporary registry, you need the following:
as-fs.tar.gz- to download it, see Downloading the installation packages.
To install the temporary Docker registry on one of the nodes, run the following command:
./configureUiPathAS.sh registry install-temp-registry -i cluster_config.json./configureUiPathAS.sh registry install-temp-registry -i cluster_config.json|
Flag |
Description |
Optional. Accepts the path to the
cluster_config.json. It is only required when changing the default registry port and file path.
30070 and uses the /uipath/data/registry file path. You must open port 30070 on the load balancer and the node on which you install the temporary docker registry.
The load balancer backend pool must exclusively target the nodes hosting the temporary docker registry.
cluster_config.json file as shown in the following sample:
"infra": {
"tmp_docker_registry": {
"node_port": "<new port number>",
"file_path": "/uipath/data/registry"
"infra": {
}After installing the temporary registry, take the following steps:
Hydrate the temporary registry with the container images and Helm charts by running the following command:
./configureUiPathAS.sh registry hydrate-temp-registry --offline-bundle /uipath/tmp/as-fs.tar.gz -i cluster_config.json./configureUiPathAS.sh registry hydrate-temp-registry --offline-bundle /uipath/tmp/as-fs.tar.gz -i cluster_config.json
Flag |
Description |
File path containing the location of the
as-fs.tar.gz on your server node.
cluster_config.json file. It is only required when changing the default Docker registry port and file path.
