- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- After Disaster Recovery Dapr is not working properly for Task Mining
- Exploring Logs
- Exploring summarized telemetry
After a Disaster Recovery, Dapr is not restored properly, and the certificates needed by dapr to provide services for Process Mining and Task Mining are incorrect. The dapr, processmining, and taskmining applications appear to be healthy first, but will then go back to progressing state and the environment becomes unstable. When logging in to Process Mining or Task Mining, the application may not load, or return unexpected errors.
This page describes the steps you should take to resolve the issue.
Delete all dapr secrets and the mutatingwebhookconfiguration.
Resync all dapr secrets and the mutatingwebhookconfiguration.
Restart dapr-sentry deployment and wait to the deployment is finished.
Restart dapr-operator deployment and wait to the deployment is finished.
Restart dapr-sidecar-injector deployment and wait to the deployment is finished.
A detailed description of the steps is provided next.
Go to Applications in ArgoCD.
Select the dapr application card to open the dapr app details tree.
Locate the dapr secrets.The secrets must be recreated. You can do this by deleting each secret.
Open the context menu of the secret and select Delete.
In the Delete resource confirmation dialog enter the name of the secret and select OK to confirm.
Repeat steps 4 and 5 for the remaining secrets.
In the dapr app details tree, locate the mutatingwebhookconfiguration.
Note:You can recognize the mutatingwebhookconfiguration from the label MWC.
Open the context menu of the secret and select Delete. In the Delete resource confirmation dialog enter the name of the mutatingwebhookconfiguration and select OK to confirm.
Some of the secrets are immediately recreated. This is indicated by a green check mark on the secret card.If a secret is not recreated, you need to sync to recreate the secret.
Locate the secret you want to recreate and select Sync from the context menu.
In the pop-up panel, select SYNCHRONIZE.
Repeat steps 2 and 3 for all the secrets that you want to recreate.
Open the context menu for the mutatingwebhookconfiguration and select Sync.
After you deleted and synchronized the secrets and the mutatingwebhookconfiguration, you need to restart the deployment.
In the dapr app details tree, locate the dapr-sentry deploy card.
Open the context menu and select Restart.
A confirmation dialog is displayed. - Select OK to confirm the restart. The dapr-sentry deployment starts. When the deployment is finished, a green heart appears. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr-operator deploy card.
In the confirmation dialog, select OK to confirm the restart. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr- sidecar-injector deploy card.
Restart the deployments in the described order and make sure a deployment is ready before starting the next deployment.
dapr-sentry
dapr-operator
