- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Oct 13, 2025
uipathctl
is included in the as-installer.zip
installation package. To download installer.zip
, see Downloading the installation packages.
To generate the cluster_config.json
configuration file, take one of the following steps:
- Option A: Generate the latest
cluster_config.json
file:uipathctl manifest get-revision | Out-File -Encoding ascii cluster_config.json
uipathctl manifest get-revision | Out-File -Encoding ascii cluster_config.json - Option B: List all the past
cluster_config.json
files and determine which one you want to choose:uipathctl manifest list-revisions
- Move the
versions.json
file to the same directory ascluster_config.json
. You can getversions.json
from the Automation Suite installation folder. - Provide the new connection strings for the installed products.
To provide the restored connection string to the Orchestrator service, add or update
sql_connection_str
underorchestrator
in thecluster_config.json
file:"orchestrator": { "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true }
"orchestrator": { "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true } -
If Test Automation tables are placed inside the standalone Orchestrator database, you can also add the same connection string for Test Automation feature inside the
cluster_config.json
file:"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchestrator connection string>" }, "sql_connection_str": "<restored orchestrator connection string>", (added line) "enabled": true }
"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchestrator connection string>" }, "sql_connection_str": "<restored orchestrator connection string>", (added line) "enabled": true } - To provide the restored connection string to the Insights service, add or update
sql_connection_str
underinsights
file."insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }
- Update the
cluster_config.json
file by running the installer.- To migrate Orchestrator
only, run the following command:
uipathctl manifest apply cluster_config.json --only orchestrator --versions versions.json
uipathctl manifest apply cluster_config.json --only orchestrator --versions versions.json - To migrate Insights only, run the following command:
uipathctl manifest apply cluster_config.json --only insights --versions versions.json
- Remap the organization IDs in the Insights tables.
For more details, see Remapping the organization IDs.
