Last updated Oct 3, 2025
Upgrade fails due to unhealthy Ceph
When trying to upgrade to a new Automation Suite version, you might see the following error message: Ceph objectstore is not completely healthy at the moment. Inner exception - Timeout waiting for all PGs to become active+clean.
Solution
To fix this upgrade issue, verify if the OSD pods are running and healthy by running the following command:
kubectl -n rook-ceph get pod -l app=rook-ceph-osd  --no-headers | grep -P '([0-9])/\1'  -vkubectl -n rook-ceph get pod -l app=rook-ceph-osd  --no-headers | grep -P '([0-9])/\1'  -v
  • If the command does not output any pods, verify if Ceph placement groups (PGs) are recovering or not by running the following command:
    function is_ceph_pg_active_clean() {
      local return_code=1
      if kubectl -n rook-ceph exec  deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count)  // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then
        return_code=0
      fi
      [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean"
      if [[ $return_code -ne 0 ]]; then
        echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean"
        kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv'
      fi
      return "${return_code}"
    # Execute the function multiple times to get updated ceph PG status
    is_ceph_pg_active_cleanfunction is_ceph_pg_active_clean() {
      local return_code=1
        return_code=0
      fi
      fi
    Note: If none of the affected Ceph PG recovers even after waiting for more than 30 minutes, raise a ticket with UiPath® Support.
  • If the command outputs pod(s), you must first fix the issue affecting them:
    • If a pod is stuck in Init:0/4, then it could be a PV provider (Longhorn) issue. To debut this issue, raise a ticket with UiPath® Support.
    • If a pod is in CrashLoopBackOff, fix the issue by running the following command:
      function cleanup_crashing_osd() {
          local restart_operator="false"
          local min_required_healthy_osd=1
          local in_osd
          local up_osd
          local healthy_osd_pod_count
          local crashed_osd_deploy
          local crashed_pvc_name
          if ! kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool ls detail  | grep 'rook-ceph.rgw.buckets.data' | grep -q 'replicated'; then
              min_required_healthy_osd=2
          fi
          in_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status   -f json  | jq -r '.osdmap.num_in_osds')
          up_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status   -f json  | jq -r '.osdmap.num_up_osds')
          healthy_osd_pod_count=$(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'Running' | grep -c -P '([0-9])/\1')
          if ! [[ $in_osd -ge $min_required_healthy_osd && $up_osd -ge $min_required_healthy_osd && $healthy_osd_pod_count -ge $min_required_healthy_osd ]]; then
              return
          fi
          for crashed_osd_deploy in $(kubectl -n rook-ceph get pod -l app=rook-ceph-osd  | grep 'CrashLoopBackOff' | cut -d'-' -f'1-4') ; do
              if kubectl -n rook-ceph logs "deployment/${crashed_osd_deploy}" | grep -q '/crash/'; then
                  echo "Found crashing OSD deployment: '${crashed_osd_deploy}'"
                  crashed_pvc_name=$(kubectl -n rook-ceph get deployment "${crashed_osd_deploy}" -o json | jq -r '.metadata.labels["ceph.rook.io/pvc"]')
                  info "Removing crashing OSD deployment: '${crashed_osd_deploy}' and PVC: '${crashed_pvc_name}'"
                  timeout 60  kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" || kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" --force --grace-period=0
                  timeout 100 kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" || kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" --force --grace-period=0
                  restart_operator="true"
              fi
          done
          if [[ $restart_operator == "true" ]]; then
              kubectl -n rook-ceph rollout restart deployment/rook-ceph-operator
          fi
          return 0
      # Execute the cleanup function
      cleanup_crashing_osdfunction cleanup_crashing_osd() {
          local in_osd
          local up_osd
          fi
              return
          fi
              fi
          done
          fi
          return 0
After fixing the crashing OSD, verify if PGs are recovering or not by running the following command:
is_ceph_pg_active_cleanis_ceph_pg_active_clean
  • Description
  • Solution
