- Overview
 - Requirements
 - Deployment templates
 - Step 2: Configuring the OCI-compliant registry for offline installations
 - Step 3: Configuring the external objectstore
 - Step 4: Configuring High Availability Add-on
 - Step 5: Configuring SQL databases
 - Step 6: Configuring the load balancer
 - Step 7: Configuring the DNS
 - Step 8: Configuring the disks
 - Step 9: Configuring kernel and OS level settings
 - Step 10: Configuring the node ports
 - Step 11: Applying miscellaneous settings
 - Step 13: Generating cluster_config.json
 - Certificate configuration
 - Database configuration
 - Kerberos authentication configuration
 - Monitoring configuration
 - Cluster administration
- Managing products
 - Migrating from in-cluster to external High Availability Add-on
 - Migrating to an external OCI-compliant registry
 - Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
 - Monitoring and alerting
 - Migration and upgrade
 - Step 8: Deleting the default tenant
 - Upgrading Automation Suite
 - Executing the upgrade
- Using the Orchestrator Configurator Tool
 - Orchestrator appSettings
 - Configuring appSettings
 - Troubleshooting
 - How to clear Redis data
 - How to enable Istio logging
 - How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
 - How to forward application logs to Splunk
 - How to clean up unused Docker images from registry pods
 - Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
 - RKE2 not getting started due to space issue
 - In-place upgrade timeouts
 - AI Center provisioning failure after upgrading to 2023.10 or later
 - SQL validation fails during upgrade
 - Longhorn REST API endpoint upgrade/reinstall error
 - ArgoCD login failed
 - Redis probe failure
 - RKE2 server fails to start
 - Pods stuck in Init:0/X
 - Failure to configure email alerts post upgrade
 - No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
 - Failed status when creating a data labeling session
 - Failed status when trying to deploy an ML skill
 - Migration job fails in ArgoCD
 - Handwriting recognition with intelligent form extractor not working
 - Failed ML skill deployment due to token expiry
 - After Disaster Recovery Dapr is not working properly for Process Mining
 - Configuring Dapr with Redis in cluster mode
 - Exploring Logs
 - Exploring summarized telemetry
Last updated Oct 13, 2025
If you are not able to create data labeling sessions on Data Manager in AI Center, take the following steps.
Please double-check if Document Understanding is properly enabled. You should have updated the configuration file before the
                  installation and set
               documentunderstanding.enabled to True, or you could update it in ArgoCD post-installation as described in Solution 2.
               After doing that, you need to disable it and disable AI Center on the tenant you wish to use the Data Labeling feature on, or create a new tenant.
