- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Manual: Installing Automation Suite
- Disaster recovery - Installing the secondary cluster
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
The following table lists the steps you must perform for single-node and multi-node installations:
Steps |
Single-node installation |
Multi-node installation |
Prerequisite |
Step 1: Accepting the license agreement |
Step 2: Installing the Infrastructure on the first server machine |
Step 3: Installing the infrastructure on the other server machines |
Step 4: Installing the infrastructure on all the agent machines |
Step 5: Completing the installation |
KUBECONFIG
environment variable to point to the RKE2
Kubernetes configuration file and update the PATH
to include the RKE2 tools directory using the following export commands:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml
export PATH=$PATH:/var/lib/rancher/rke2/bin
Before running the installation, make sure to read the license agreement.
To accept the license agreement, choose one of the following methods:
- Option 1 (Environment variable) - Set the
LICENSE_AGREEMENT
environment variable toaccept
by running the following command:export LICENSE_AGREEMENT=accept
- Option 2 (Inline parameter) - Append
--accept-license-agreement
to every execution ofinstall-uipath.sh
To install the infrastructure on the first server machine, navigate to the installer folder and run the following command:
cd /opt/UiPathAutomationSuite/<version>/installer
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k --accept-license-agreement
The
-k
parameter installs the infrastructure on the first server machine. -
Once the infrastructure is installed, the server machine becomes a node in the Automation Suite cluster.
To expand the Automation Suite cluster, install the infrastructure on the additional server machines.
To do that, run the following command on all the additional server machines:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j server --accept-license-agreement
-j server
parameter adds the machines as server nodes to the existing Automation Suite cluster. The fixed_rke_address
flag in the cluster_config.json
file connects the exiting Automation Suite cluster.
If you have additional agent machines, you must install the infrastructure on those machines and add them as agent nodes to the Automation Suite cluster.
To to that, run the following command on all the agents machines:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j agent --accept-license-agreement
-j agent
parameter adds the machines as agent nodes to the existing Automation Suite cluster. The fixed_rke_address
At this point, all the nodes should be interconnected to establish the infrastructure for installing Automation Suite. To verify if all nodes are available on the first server node and to complete the installation, run the following command:
kubectl get nodes
kubectl get nodes
The output of the aforementioned command should look similar to the one shown in the following image. Note that the total number of nodes must match the sum of server and agent nodes.
After verifying the infrastructure, install the fabric and the services by running the following command:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f -s --accept-license-agreement
