- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
The Template-hosting S3 Region parameter must match exactly the AWS region in which you try to deploy. If the region does not match, the deployment does not succeed.
Keep the default settings for the parameters labeled Quick Start S3 bucket name, Quick Start S3 bucket Region, and Quick Start S3 key prefix. If these input parameters are altered, the deployment does not succeed.
Parameter label (name) |
Template |
Default value |
Description |
Availability Zones |
Choose up to three Availability Zones to use for the VPC subnets. |
Number of Availability Zones |
Choose the number of Availability Zones to use in the VPC. For a new VPC, this must match the number you set using the Availability Zones parameter. For an existing VPC, you can set two or three Availability Zones. |
Deploy Bastion host |
Deploy a Bastion host inside the public subnet. |
Template |
Default value |
Description |
VPC CIDR |
VPC CIDR block. Example:
x.y.0.0/16, x.y.z.0/24.
VPC ID |
ID of the existing VPC. |
Public subnet IDs |
List of public subnet IDs where the internet-facing Load Balancer and the Bastion host will be deployed. |
Private subnet IDs |
List of private subnet IDs. |
Template |
Default value |
Description |
Instance key pair |
Existing key pair to connect to virtual machine (VM) instances. |
Instance AMI ID |
AMI ID to use for the creation of the EC2 instances of the cluster. When the AMI ID is not specified, the default version deployed is RHEL 8.3 for non GPU VM and RHEL 8.2 for GPU VM. |
GPU instance AMI ID |
AMI ID to use for the creation of the GPU-enabled EC2 instance. |
IAM Role ARN |
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment. |
IAM Role name |
Name of a pre-deployed IAM Role with sufficient permissions for the deployment |
Template |
Default value |
Description |
Deployment type |
Install Automation Suite in single-node evaluation mode or multi-node HA-ready production mode. |
Enable cluster backup |
Enable the cluster backup. |
| Use a shared bucket for external storage |
| false | Enable a shared bucket across products. If you choose true, Process Mining and Data Service require a dedicated bucket each.
Load Balancer |
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you must configure the TLS certificates manually post deployment. |
Perform Installation |
Perform the Automation Suite installation. |
Automation Suite Version |
e.g.
22.10.0 |
Automation Suite version to install. |
Installer download URL |
Custom URL for installer download. Leave empty to use the UiPath version. |
| Add GPU-enabled VMs |
| false | Choose true to add a GPU-enabled VM to the deployment.
Extra configuration keys |
Extra configuration keys to add to the cluster configuration. |
| Validity of the self-signed certificate |
| Validity, in days, of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC. |
Template |
Default value |
Description |
Service install flags (multiple) |
Choose if a specific service is installed in the cluster. |
Template |
Default value |
Description |
Connect AI Center to an external Orchestrator |
Register AI Center to an external Orchestrator. |
Orchestrator URL |
URL of the external Orchestrator. Example:
https://my-orchestrator.net |
Identity URL |
URL of the Identity server used. Example:
https://my-orchestrator.net/identity |
Base64 encoded Orchestrator certificate |
Base64-encoded Orchestrator certificate string. Example:
UExBQ0VIT0xERVI= |
Base64 encoded Identity certificate |
Base64-encoded Identity certificate string. Example:
UExBQ0VIT0xERVI= |
Templates |
Default value |
Description |
Hosting FQDN |
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the of
ID of Route 53 hosted zone parameter.
ID of Route 53-hosted zone |
Enter the ID of the Route 53-hosted zone or leave blank. For details, see Valid domain name. |
ARN of the ACM-hosted certificate |
ARN of the certificate present in the ACM (Amazon Certificate Manager) to use with the ALB. |
Use Internal Load Balancer |
Choose if you want to use an internal load balancer. |
Template |
Default value |
Description |
Engine of SQL Server deployed on RDS |
Choose the RDS Microsoft SQL engine. |
Version of SQL Server deployed on RDS |
Choose the RDS Microsoft SQL version. |
AWS KMS Key ID used to encrypt RDS storage |
KMS Key ID to use for the encryption of the RDS storage. |
| Parameter label (name) | Template | Default value | Description |
| Template folder |
| You must not change the value. |
Template-hosting S3 Region |
Must match the region where you deploy the resources in AWS. For example, if you want to deploy in
us-east-1, select us-east-1.
- Table 1. Availability Zone configuration
- Table 2. Network configuration
- Table 3. Automation Suite instance configuration
- Table 4. Automation Suite deployment configuration
- Table 5. Automation Suite service configuration
- Table 6. Automation Suite external Orchestrator configuration
- Table 7. DNS or SSL configuration
- Table 8. Amazon RDS configuration
- Table 9. Partner Solution S3 bucket configuration
