- Overview
 - Requirements
- Q&A: Deployment templates
 - Install-uipath.sh Parameters
 - Enabling Redis High Availability Add-On for the cluster
 - Document Understanding configuration file
 - Cluster administration
 - Monitoring and alerting
 - Migration and upgrade
- Migration options
 - Troubleshooting
 - How to clear Redis data
 - How to enable Istio logging
 - Unable to launch Automation Hub and Apps with proxy setup
 - Failure to resize PVC
 - Failure to resize objectstore PVC
 - Storage reclamation patch
 - ArgoCD login failed
 - Redis probe failure
 - RKE2 server fails to start
 - MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
 - Pods stuck in Init:0/X
 - Exploring Logs
Last updated Jun 30, 2025
After performing an Automation Suite cluster upgrade, some changes are needed to ensure a new node joins the cluster correctly.
                  To automate the changes, we recommend using the
               upgradeUiPathAS.sh script.
               This page provides instructions on how to replace the Custom Script Extension (CSE) on the compute resources so that new nodes can be added to your cluster when upgrading to a new Automation Suite version.
The process described in the following sections downloads the scripts required to perform some minor modifications to the
                  Azure resources as well as to validate some prerequisites. The scripts are found inside the
               <targetVersion> and Modules folders. If the process fails, you are asked whether you want to keep the files.
               After ensuring that prerequisites are valid, the
            CustomScriptExtension objects are updated on all our compute resources so that newly added nodes use the Automation Suite <targetVersion>. Lastly, the files on the initial cluster nodes are overwritten, to also match the files from the <targetVersion>.
               Prerequisites
Make sure you meet the following requirements:
- You must add the Managed Service Identity (MSI) associated with the deployment (named like
<basename>-MSI) as a user assigned identity to all the scalesets/virtual machines in the deployment. To do this, go to Scaleset/virtual machine > Identity > User Assigned > Add. Newer versions of Automation Suite templates might already have this added. - You must grant the existing MSI rights to read/write/manage secrets in the deployed key vault (named like
<basename>-VAULT). To do this, go to the keyvault, click Access Policies, then Add, select all Secret Operations, choose the MSI, then Add. - Make sure to review the
cluster_config.jsonfile and change any boolean values marked as string ("true"/"false") to actual boolean values (true/false). For example:- to enable zone resilience,
                              use
"zone_resilience": true. - to allow the installer to
                              create the databases, use
"sql.create_db": true.
Note:If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or later, and Orchestrator is enabled on both the old and new versions, you must set theorchestrator.block_classic_executionsflag totruein thecluster_config.jsonfile. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - to enable zone resilience,
                              use
 - After the upgrade process, export the new
cluster_config.jsonfile contents to an Azure key vault secret namedclusterConfigin the deployment key vault (for details, see the previous list item). Use the value of theFixedRKEAddressfield as the IP of the Internal Load Balancer. To do this, run a command similar to the following:az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json)az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json) - On the machine running the upgrade script, you must be logged into Azure and set the context to the correct subscription.
                        The account must have the
Ownerrole on the resource group where the cluster was deployed.
Considerations and recommendations
Before starting the upgrade operation, make sure to take the following recommendations into consideration:
- We strongly recommend updating to the latest RHEL OS version supported by Automation Suite. For details, see Deployment profiles at a glance.
 - Before starting the upgrade operation, you can create two containers named
logsandflagsin the deployment storage account (named<basename>st). If you do not create them, the upgrade script can do that for you. - If the deployed server scalesets do not have a Ceph disk attached, the script creates one and attaches it to the server scaleset.
 - The upgrade process changes the VMSS model but does not apply it for older instances.
 - For details on the upgrade errors you might encounter, see Manual: Online upgrade and Automated: Online upgrade.
To successfully perform to upgrade to a new Automation Suite version, take the following steps:
Parameters
You can find descriptions of the parameters needed to update to a specific Automation Suite version in the
               cluster_config.json file. You can find the cluster_config.json file at this link.
