- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This page lists the steps you need to take before deploying Automation Suite to AWS.
The AWS deployment requires a moderate level of familiarity with AWS services.
If you are new to AWS, you can start by reading the following introductory materials to get familiar. They provide basic materials for how to design, deploy, and operate infrastructure and applications on the AWS Cloud.
This Quick Start also assumes familiarity with AWS Services listed in the Request resources quotas section of this guide. For a detailed diagram and description of the architecture, see:
If you don’t already have an AWS account, create one by following the step-by-step instructions. Your AWS account is automatically signed up for all AWS services. You are charged only for the services you use.
The following sections walk you through the steps you need to take to configure your AWS Account specific to the Automation Suite deployment requirements.
Amazon EC2 key pairs
You need at least one EC2 key pair in the AWS account in the Region where you will deploy the Quick Start.
To create a key pair, see Amazon EC2 key pairs and Linux instances.
Take note of the key-pair name as it is needed during the deployment.
Valid domain name
This Quick Start requires you to have established ownership of the parent domain under which the web application will be served. If you want to register a domain, see Registering a public domain.
If you have registered the domain using AWS Route 53, then the hosted zone is preconfigured, and no additional configuration is necessary.
Otherwise, you should set up a hosted zone in your AWS account, with the required name server, start of authority, CNAME, and text records. For further details on how to create a public hosted zone, see Working with public hosted zones.
WaitConditionHandle resource in the routing stack. The Physical Id of this resource is an URL. Execute a POST request as described here.
Request resource quotas
If necessary, request service quota increases for the following resources. You might need to request increases if your existing deployment currently uses these resources and if this Quick Start deployment could result in exceeding the default quotas. The Service Quotas console displays your usage and quotas for some aspects of some services.
For more information, see What is Service Quotas? and AWS service quotas.
Resource |
Requirement |
VPCs |
1 |
Subnets |
Up to 6 |
NAT gateways |
2 |
VPC endpoints |
1 |
Internet gateways |
1 |
Elastic IP addresses |
Up to 6 |
AWS Identity and Access Management (IAM) security groups |
1 |
IAM roles |
Up to 7 |
Auto Scaling groups |
Up to 2 |
Application Load Balancers |
Either 0 or 1 |
Network Load Balancers |
Either 1 or 2 |
Public certificate authorities (CA) |
1 |
Hosted zone |
1 |
RDS instances |
1 |
Bastion hosts |
1 |
Secrets |
4 |
Parameters in Parameter Store |
3 |
SSM documents |
Either 0 or 3 |
Lambda Functions |
3 |
Instance Profiles |
2 |
Security Groups |
3 |
Supported AWS regions
In order for the Quick Start to work in a Region other than its default Region, all the services that are part of the deployment must also be supported in that Region.
For an up-to-date list of AWS Regions and the AWS services they support, see AWS Regional Services.
Unrecognized resource type error, then Quick Start is not
IAM permissions
Before launching the Quick Start, you must sign in to the AWS Management Console with IAM permissions for the resources that the templates deploy. The AdministratorAccess managed policy within IAM provides sufficient permissions, although your organization may choose to use a custom policy with more restrictions.
For more information, see AWS managed policies for job functions.
For a complete list of roles and policies that the CloudFormation template creates, see Roles and policies.
The following table describes all the external endpoints that the service interacts with:
Requirements |
Details |
| AWS metadata service |
Provides details about your Amazon EC2 instance |
| AWS management APIs |
Used via AWS CLI or lambda functions |
| AWS bootstrap archive |
Used for services to provision and manage resources. Retrieved from the following URL:
https://s3.amazonaws.com/cloudformation-examples/aws-cfn-bootstrap-py3-latest.tar.gz |
| AWS CLI package |
Used for the command line interface to interact with AWS services from a machine. You can access the package from the following
URL:
https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip |
| AWS SSM Agent |
Used for managing instances via remote commands at scale. You can download the agent from the following URL:
https://s3.${AWS::Region}.amazonaws.com/amazon-ssm-${AWS::Region}/latest/linux_amd64/amazon-ssm-agent.rpm |
| AWS Cloudwatch Agent |
Used for collecting system and application logs for monitoring. You can download the agent from the following URL:
https://s3.amazonaws.com/amazoncloudwatch-agent/redhat/amd64/latest/amazon-cloudwatch-agent.rpm |
| Nvidia drivers |
Required for GPU-enabled VMs. You can get the drivers from the Nvidia repository. |
| External repository if used |
N/A |
| UiPath S3 buckets for templates / lambda functions usage / bash scripts for installation. |
N/A |
For more details, see Network requirements.
Connect AiCenter to an external Orchestrator to true and provide certificates for Orchestrator and Identity to the parameters listed in AWS deployment parameters. For details on how to obtain the certificates, see Chain certificates.
To encode the certificates in base64 format, run the following commands:
cat orchestrator.cer | base64 | tr -d '\n' > orchestratorCert
cat identity.cer | base64 | tr -d '\n' > identityCertcat orchestrator.cer | base64 | tr -d '\n' > orchestratorCert
cat identity.cer | base64 | tr -d '\n' > identityCertTo register AI Center to the external Orchestrator, you must run this SSM document.
