- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Jun 30, 2025
The documentation lists
wget
as an option for downloading the bundles. Because of the large sizes, the connection may be interrupted and not recover.
One way to mitigate this could be to switch to a different download tool, such as
azcopy
(more information here). Run these commands, while updating the bundle URL to match the desired version/bundle combination.
wget https://aka.ms/downloadazcopy-v10-linux -O azcopy.tar.gz
tar -xvf ./azcopy.tar.gz
azcopy_linux_amd64_10.11.0/azcopy copy https://download.uipath.com/service-fabric/0.0.23-private4/sf-0.0.23-private4.tar.gz /var/tmp/sf.tar.gz --from-to BlobLocal
