- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Jun 30, 2025
In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
To fix the issue, you must create a
ServiceEntry
, as shown in the following example:
apiVersion: networking.istio.io/v1beta1
kind: ServiceEntry
metadata:
namespace: <uipath>
spec:
hosts:
- <proxy-host>
addresses:
- <proxy-ip>/32
ports:
- number: <proxy-port>
protocol: TCP
kind: ServiceEntry
metadata:
namespace: <uipath>
spec:
hosts:
- <proxy-host>
addresses:
- <proxy-ip>/32
ports:
protocol: TCP
