Last updated Nov 6, 2025
GSSAPI operation failed due to invalid status code
This log could be found when using Kerberos for SQL access, and SQL connection is failing inside services. Similarly, you may see kinit: Client's credentials have been revoked while getting initial credential in one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Solution
This could be caused by the AD user account used to generate the keytab being disabled. Re-enabling the AD user account should fix the issue.
  • Description
  • Solution
