- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Ansible is used to automate the upgrade of the entire Automation Suite cluster, by performing some operations on one machine in the cluster.
In the following illustration, the Server 1 node (or Ansible host node) uses Ansible to orchestrate the upgrade of entire Automation Suite cluster.
uipathctl.sh script. For details, see Using uipathctl.sh.
/opt/UiPathAutomationSuite folder on all the nodes. If you do not have enough space, you can either increase the capacity of this folder or remove all
the previous installer files except for cluster_config.json. You can always download the previous installer again.
df -h /opt/UiPathAutomationSuite.
To prepare for the upgrade, take the following steps:
See also Manual: Advanced installation experience.
zone_resilience flag to false in the cluster_config.json file in /opt/UiPathAutomationSuite/Installer.
If any errors or issues occur during or following the upgrade, you can rollback to the previous version, provided that you previously configured a backup.
For instructions, see Rollback on error.
Configuring the backup
To configure the backup, take the following steps:
Once the backup is created, continue with the following steps.
Putting the cluster in maintenance mode
Putting the cluster in maintenance mode will shut down the ingress controller and all the UiPath services, blocking all the incoming traffic to the Automation Suite cluster.
Upgrading the Cluster
To upgrade the Automation Suite cluster, take the following steps:
Basic parameters
Parameter |
Value |
Possible values:
online and offline.
Since this page provides instructions for an online environment, choose the
online value.
Possible values are:
all, infra, fabric, and services. Denotes each stage of the installation and upgrade process.
If an error occurs during the upgrade, you can use these checkpoints to resume the upgrade operation instead of retrying from start. |
cluster_config.json file, which defines the parameters, settings, and preferences applied to the UiPath services deployed via Automation Suite.
Advanced parameters
Parameter |
Value |
Specify the username to be used for SSH connections to all the nodes. Defaults to the current user. If you use a different
username for all the nodes, then instead of using this parameter, set the username for all the nodes in
inventory.ini and pass it to the script.
Example: While running the script, you are logged in as the
myadminuser username. However, if you want to use the testadmin username to connect via SSH, you must provide testadmin to this parameter.
Specify an existing Ansible inventory file. If not specified, one will be generated automatically from the existing cluster with the basic configuration. In certain scenarios where you want to have more granular control, you may want to provide your own inventory file. One such example would be if you want to use a different SSH username or SSH key for all the nodes in cluster. For details, see Generating the Ansible inventory.ini file. |
After performing the upgrade, you can take the following additional steps.
To verify if Automation Suite is healthy, run:
kubectl get applications -n argocdkubectl get applications -n argocd -
If you experience issues with image vulnerabilities or storage consumption after performing an upgrade, delete the images from the old installer. For details, see the Troubleshooting section.
Enabling the backup post-upgrade
Before starting to upgrade the cluster, the upgrade script automatically creates a backup of the cluster and then temporarily disables it. You may want to enable the backup manually once the upgrade is done.
To enable the backup, follow the instructions in described in the Backing up and restoring the cluster documentation.
After performing an Automation Suite cluster upgrade, Azure and AWS template deployments require some changes to ensure a new node joins the cluster correctly through scale-out operations. To automate the changes, we recommend using the dedicated scripts. For instructions, see the Azure deployment template docs and the AWS deployment template docs.
Special considerations
When performing an upgrade for a cluster deployed with Azure templates, an error similar to the one shown in the following image might occur:
fixed_rke_address field in the cluster_config.json file. You must change the value of this field to the IP address of the first server instance prior to running the upgrade
command. The cluster_config.json uploaded to the key vault should continue to have the IP address of the ILB since the node is not healthy, and traffic will
not be balanced to it.
