Last updated Jun 30, 2025
Step 1.2: Configuring the VM
Configuring the DNS of the VM
Note: Configuring the DNS on each VM is optional if you are deploying a multi-node HA-ready production setup behind a load balancer.
  1. Select the value of the DNS Name to set the DNS name of the machine.
  2. In the VM IP configuration window displayed, set the DNS name label:
  3. Select Save.
Testing the Connection to the VM
Test the connection to the VM using SSH. Request Just In Time access if needed.
  • To connect to the machine using SSH, follow the Azure instructions.
  • Alternatively, you can connect to the machine on your terminal using SSH:
    # If you set a password the command is:
    ssh <user>@<dns_of_vm>
    # If you used an ssh key:
    ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm># If you set a password the command is:
Partitioning the Disk
Log in to the machine via SSH using the following commands:
  • If you set a password:
    ssh <user>@<dns_of_vm>ssh <user>@<dns_of_vm>
  • If you used an SSH key:
    ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Identifying the Device Name for the Disk in Azure
Note:
The disk device name is different from the disk name. You will need the disk device name when configuring the disk.
To configure the disk for installation, see the following:
  1. In the Disks tab of every VM in the Azure portal, you can find the LUN (Logical Unit Number) corresponding to each attached disk.
  2. Run the following command to identify the disk device name, where LUN=<lun_value> as identified in the Azure portal:
    LUN=<lun_value>
    echo "/dev/$(tree /dev/disk/azure/ | grep -w "\slun${LUN}\s" | awk -F/ '{print $NF}')"LUN=<lun_value>
Marking the Azure Disk as SSD
Note: This step is required only for data disk and raw disk.
You need to mark the Azure disk as SSD by running the following command:
echo "0" > "/sys/block/{DEVICE_NAME}/queue/rotational"
echo "KERNEL==\"{DEVICE_NAME}\", ATTR{queue/rotational}=\"0\"" >> "/etc/udev/rules.d/99-azure-mark-ssd.rules"
udevadm control --reload
udevadm triggerecho "0" > "/sys/block/{DEVICE_NAME}/queue/rotational"
udevadm trigger
Multi-node Only: Configuring Additional Ports
These additional inbound ports are needed only for multi-node HA-ready production installations. Add them to all VMs.
Port
Protocol
Source
Destination
Purpose
443
TCP
Any
Any
https traffic
2379
TCP
VirtualNetwork
VirtualNetwork
etcd client port
2380
TCP
VirtualNetwork
VirtualNetwork
etcd peer port
6443
TCP
Any
Any
Kubernetes API
8472
UDP
VirtualNetwork
VirtualNetwork
Flannel
9345
TCP
Any
Any
Kubernetes API
10250
TCP
VirtualNetwork
VirtualNetwork
kubelet
30071
TCP
VirtualNetwork
VirtualNetwork
NodePort
Opening TCP ports on an Azure VM for multi-node installations
Create new inbound networking rules for the ports needed over TCP protocol.
  1. Select the VM’s Overview tab, then select the Networking tab:
  2. Select Add inbound port rule.
  3. Change the fields as required:
    • Destination port range
    • Protocol
    • Name
      You can add as a comma-separated list with ranges:
  4. Add all the TCP in one inbound rule as previously shown, and the UDP in a separate one. For the UDP, add +1 to the priority.
  5. And select Add.
