- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
If service installation fails in a cluster using ceph as incluster object store, and checking
kubectl -n uipath get pods returns failed pods, take the following steps.
- Check
kubectl -n uipath describe pod <pod-name>and look for secret not found. - If the secret is not found, then look for credential manager job logs and see if it failed.
# get the credential manager pod name kubectl -n istio-system get pods | grep credential-manager # check the credential manager pod logs kubectl -n istio-system logs <credential-manager-pod-name># get the credential manager pod name kubectl -n istio-system get pods | grep credential-manager # check the credential manager pod logs kubectl -n istio-system logs <credential-manager-pod-name> - If the credential manager job failed and
kubectl get pods -n rook-ceph|grep rook-ceph-toolreturns more than one pod, do the following:- delete
rook-ceph-toolthat is not running. - go to ArgoCD UI and sync
sfcoreappllication to retrigger the credential manager job. - Once the credential manager job completes, check if all secrets are created by looking at the credential-manager job logs.
- Now sync the application corresponding to the failed pod.
- delete
