- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Compatibility matrix
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
When migrating from a standalone product to Automation Suite, you must make sure the versions of the standalone product, UiPath.OrganizationMigrationApp, and Automation Suite are compatible.
The following table describes the version compatibility required to perform a migration to Automation Suite:
Standalone product version | UiPath.OrganizationMigrationApp
version | Automation Suite version | |
| Orchestrator | Insights | ||
| 2022.10.15 | 2022.10.12 | 2022.10.14 | 2022.10.14 |
| 2022.10.13 | 2022.10.11 | 2022.10.14 | 2022.10.13 |
| 2022.10.12 | 2022.10.10 | 2022.10.12 | 2022.10.12 |
| 2022.10.11 | 2022.10.9 | 2022.10.11 | 2022.10.11 |
| 2022.10.10 | N/A | 2022.10.10 | 2022.10.10 |
| 2022.10.8 | N/A | 2022.10.8 | 2022.10.9 |
| 2022.10.7 | N/A | 2022.10.7 | 2022.10.8 |
| 2022.10.6 | N/A | 2022.10.6 | 2022.10.7 |
| 2022.10.5 | N/A | 2022.10.5 | 2022.10.6 |
How to read the table
As an example, to migrate standalone Orchestrator 2022.10.5, you must use UiPath.OrganizationMigrationApp 2022.10.5 and make sure that you installed Automation Suite 2022.10.6.
For information on updates to the UiPath.OrganizationMigrationApp and the migration workflows, see the release notes for your targeted Automation Suite version by clicking the corresponding link in the Automation Suite version column. If there is no entry dedicated to the UiPath.OrganizationMigrationApp in the release notes, this means that we made only minor improvements to the tool.
