- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
If the Longhorn replicas are in a faulted state and require manual salvage, the volume may not be able to attach and remain in a detach state.
To check if the volume requires manual salvage, run the following commands:
kubectl logs -l app=longhorn-manager -n longhorn-system -c longhorn-manager --prefix=true --tail=-1 |grep "set engine salvageRequested to true" | grep <PV NAME>kubectl logs -l app=longhorn-manager -n longhorn-system -c longhorn-manager --prefix=true --tail=-1 |grep "set engine salvageRequested to true" | grep <PV NAME>Sample output:
2023-11-20T18:22:16.667609096+11:00 time="2023-11-20T07:22:16Z" level=info msg="All replicas are failed, set engine salvageRequested to true" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=rpa-suite-dev-01.it.csiro.au owner=rpa-suite-dev-01.it.csiro.au state=detaching volume=pvc-031fd6bc-9cfe-420a-9213-da38509d733a2023-11-20T18:22:16.667609096+11:00 time="2023-11-20T07:22:16Z" level=info msg="All replicas are failed, set engine salvageRequested to true" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=rpa-suite-dev-01.it.csiro.au owner=rpa-suite-dev-01.it.csiro.au state=detaching volume=pvc-031fd6bc-9cfe-420a-9213-da38509d733aTo fix this issue, take the following steps:
Scale down the workload pods.
Find replicas of the relevant volume by running the following command:
kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME>kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME> -
Edit the
replicas.longhorn.ioobject for the relevant PV by running the following command and set thespec.failedatfield to empty(““).kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME>kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME> -
Scale up the workload pods.
