- Overview
- Requirements
- Installation- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade- Migration options
- Troubleshooting- How to troubleshoot services during installation
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
- To connect to the machine using SSH, follow the Azure instructions.
                        Alternatively, you can connect to the machine on your terminal using SSH: # If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm># If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Log in to the machine via SSH using the following commands:
                     If you set a password: ssh <user>@<dns_of_vm>ssh <user>@<dns_of_vm>
                     If you used an SSH key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Identifying the Device Name for the Disk in Azure
The disk device name is different from the disk name. You will need the disk device name when configuring the disk.
To configure the disk for installation, see the following:
Marking the Azure Disk as SSD
You need to mark the Azure disk as SSD by running the following command:
echo "0" > "/sys/block/{DEVICE_NAME}/queue/rotational"
echo "KERNEL==\"{DEVICE_NAME}\", ATTR{queue/rotational}=\"0\"" >> "/etc/udev/rules.d/99-azure-mark-ssd.rules"
udevadm control --reload
udevadm triggerecho "0" > "/sys/block/{DEVICE_NAME}/queue/rotational"
udevadm triggerThese additional inbound ports are needed only for multi-node HA-ready production installations. Add them to all VMs.
| Port | Protocol | Source | Destination | Purpose |
| 443 | TCP | Any | Any | https traffic |
| 2379 | TCP | VirtualNetwork | VirtualNetwork | etcd client port |
| 2380 | TCP | VirtualNetwork | VirtualNetwork | etcd peer port |
| 6443 | TCP | Any | Any | Kubernetes API |
| 8472 | UDP | VirtualNetwork | VirtualNetwork | Flannel |
| 9345 | TCP | Any | Any | Kubernetes API |
| 10250 | TCP | VirtualNetwork | VirtualNetwork | kubelet |
| 30071 | TCP | VirtualNetwork | VirtualNetwork | NodePort |
Opening TCP ports on an Azure VM for multi-node installations
Create new inbound networking rules for the ports needed over TCP protocol.
