- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
After an OS upgrade, Ceph OSD pods can sometimes get stuck in
CrashLoopBackOff state. This issue causes Automation Suite not to be accessible.
Check the state of the pods by running the following command:
kubectl -n rook-ceph get podskubectl -n rook-ceph get pods -
If any of the pods in previous output are in
CrashLoopBackOff, recover them by running the following command:OSD_PODS=$(kubectl -n rook-ceph get deployment -l app=rook-ceph-rgw --no-headers | awk '{print $1}') kubectl -n rook-ceph rollout restart deploy $OSD_PODSOSD_PODS=$(kubectl -n rook-ceph get deployment -l app=rook-ceph-rgw --no-headers | awk '{print $1}') kubectl -n rook-ceph rollout restart deploy $OSD_PODS -
Wait for approximately 5 minutes for the pods to be in running state again, and check their status by running the following command:
