- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Automation Suite supports the following external objectstores:
- Azure Storage (Azure Blob Storage)
- AWS S3
- S3 compatible objectstore.
- Only some S3-compatible objectstores are compatible with Automation Suite. Many storage providers do not fully support the S3 storage APIs required by the products installed on Automation Suite.
- For Automation Suite to function properly when using pre-signed URLs, you must make sure that your external objectstore is accessible from the Automation Suite cluster, browsers, and all your machines, including workstations and robot machines.
- When configuring the external object storage, you must follow the naming rules and conventions from your provider for both
bucket_name_prefixandbucket_name_suffix. In addition to that, the suffix and prefix must have a combined length of no more than 25 characters, and you must not end the prefix or start the suffix with a hyphen (-) as we already add the character for you automatically. -
The Server Side Encryption with Key Management Service (SSE-KMS) can only be enabled on the Automation Suite buckets deployed in any region created after January 30, 2014.
SSE-KMS functionality requires pure SignV4 APIs. Regions created before January 30, 2014 do not use pure SignV4 APIs due to backward compatibility with SignV2. Therefore, SSE-KMS is only functional in regions that use SignV4 for communication. To find out when the various regions were provisioned, refer to the AWS documentation.
Your S3-compatible objectstore must have the following APIs for the products you plan to install on Automation Suite:
Platform |
Orchestrator |
AI Center |
Apps |
Document Understanding |
Test Manager |
Data Service |
Process Mining |
Task Mining | |
N/A |
N/A | |||||||
N/A |
N/A |
N/A | ||||||
N/A |
N/A |
N/A | ||||||
N/A |
N/A |
N/A |
N/A |
N/A | ||||
N/A |
N/A |
N/A | ||||||
PRESIGNED_URL | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | |
N/A |
N/A |
N/A |
N/A | |||||
N/A |
N/A |
N/A |
N/A |
N/A | ||||
N/A |
N/A |
N/A |
N/A |
N/A |
N/A | |||
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A | ||
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A | ||
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A | ||
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Make sure the following CORS policy is configured at your objectstore server or the bucket level.
This is the CORS policy in JSON format:
"AllowedHeaders": [
"AllowedMethods": [
"POST",
"GET",
"HEAD",
"DELETE",
"PUT"
"AllowedOrigins": [
"https://{{fqdn}}"
"ExposeHeaders": [
"etag",
"x-amz-server-side-encryption",
"x-amz-request-id",
"x-amz-id-2"
"MaxAgeSeconds": 3000
"AllowedHeaders": [
"AllowedMethods": [
"POST",
"GET",
"HEAD",
"DELETE",
"PUT"
"AllowedOrigins": [
"https://{{fqdn}}"
"ExposeHeaders": [
"etag",
"x-amz-request-id",
"x-amz-id-2"
]This is the CORS policy in XML format:
<CORSConfiguration>
<CORSRule>
<AllowedOrigin>*</AllowedOrigin>
<AllowedMethod>HEAD</AllowedMethod>
<AllowedMethod>GET</AllowedMethod>
<AllowedMethod>PUT</AllowedMethod>
<AllowedMethod>POST</AllowedMethod>
<AllowedMethod>DELETE</AllowedMethod>
<AllowedHeader>*</AllowedHeader>
<MaxAgeSeconds>3000</MaxAgeSeconds>
<ExposeHeader>x-amz-server-side-encryption</ExposeHeader>
<ExposeHeader>x-amz-request-id</ExposeHeader>
<ExposeHeader>x-amz-id-2</ExposeHeader>
<ExposeHeader>etag</ExposeHeader>
</CORSRule>
</CORSConfiguration><CORSConfiguration>
<CORSRule>
</CORSRule>
