- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
An Automation Suite cluster uses the objectstore disks attached to its server nodes as storage resources available to all the products enabled on your cluster. Each product uses these resources differently.
To understand your storage needs and plan for them accordingly, refer to the following terminology and guidelines.
Server node disk size – The size of all individual disks attached to each server node.
- Disks on each server may have different sizes as long as the sum of all the disk sizes is identical on all servers.
- Total cluster disk size – Server node disk size multiplied by the number of server nodes.
Application available storage – The amount of storage available for applications to consume.
- Application available storage is lower than the total storage attached. This is to ensure we have a higher resiliency to fault tolerance and high availability.
The following table describes the multi-node HA-ready hardware requirements for the Complete product selection in the context of the previously introduced terms.
Number of server nodes |
Server node disk size |
Total cluster disk size |
Application available storage |
3 |
512 GB |
1.5 TB |
512 GB |
As you enable and use products on the cluster, they consume some storage from the application available storage. Products usually have a small enablement footprint as well as some usage-dependent footprint that varies depending on the use case, scale of use, and project. The storage consumption is evenly distributed across all the storage resources (data disks), and you can monitor the levels of storage utilization using the Automation Suite monitoring stack.
How to monitor available storage
You will receive an alert with a warning when the storage consumption exceeds 75%. You will receive another critical alert when the storage consumption exceeds 85%; in this case, the storage will be read-only.
How to increase storage capacity
If your evaluated needs do not meet the recommended hardware requirements, you can add more storage capacity using either one or both of the following methods:
- You have to add a new disk on all the server nodes of same size.
- To configure the disk, see our docs.
How to calculate your usage needs
You can estimate your storage consumption using the product-specific metric in the following tables. These tables describe how much content you can place on your cluster out of the box. For reference, they include the storage footprint of a typical usage scenario of each product.
Product |
Storage-driving metric |
Storage per metric |
Typical use case |
Shared suite capabilities |
N/A |
Typically, 7 days of application logs is around 25 GB. |
Orchestrator |
Typically, a package is 5 MB, and buckets, if any, are less than 1 MB. A mature enterprise has 5 GB of packages and 6 GB of buckets deployed. |
Action Center |
Typically, a document takes 0.15 MB, and the forms to fill take an additional 0.15 KB. In a mature enterprise this can roll up to 4 GB in total. |
Test Manager |
Typically, all files and attachments add up to approximately 5 GB. |
Insights |
2 GB are required for enablement, with the storage footprint growing with the number. A well-established enterprise-scale deployment requires another few GB for all the dashboards. |
Automation Hub |
N/A |
N/A |
2 GB fixed footprint |
Automation Ops |
N/A |
N/A |
No storage footprint |
Apps |
Typically, the database takes approximately 5 GB, and a typical complex app consumes approximately 15 MB. |
AI Center |
A typical and established installation will consume 8 GB for 5 packages and an additional 1GB for the datasets. A pipeline may consume an additional 50 GB, but only when actively running. |
Document Understanding |
In a mature deployment, 12 GB will go to ML model, 17 GB to the OCR, and 50 GB to all documents stored. |
Task Mining |
Typically, about 200 GB of activity log data should be analyzed to suggest meaningful automations. Highly repetitive tasks however, may require much less data. |
Process Mining |
Minimal footprint only used by users uploading data via the Process Mining portal. Approximately 10 GB of storage should be enough in the beginning. |
