- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Jun 30, 2025
If your antivirus application leads to issues, it's recommended to raise a support ticket with the antivirus provider. While you have an option to include the following folders in the antivirus allowlist, a more appropriate solution is get help from your antivirus provider's support team:
/var/lib/rancher
/var/lib/kubelet
/opt/UiPathAutomationSuite
/datadisk
/var/lib/rancher/rke2/server/db
/var/lib/longhorn
