2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
If service installation fails, and checking
kubectl -n uipath get pods
returns failed pods, take the following steps.
- Check
kubectl -n uipath describe pod <pod-name>
and look for secret not found. - If the secret is not found, then look for credential manager job logs and see if it failed.
- If the credential manager job failed and
kubectl get pods -n rook-ceph|grep rook-ceph-tool
returns more than one pod, do the following:- delete
rook-ceph-tool
that is not running. - go to ArgoCD UI and sync
sfcore
appllication. - Once the job completes, check if all secrets are created in the credential-manager job logs
- Now sync
uipath
application.
- delete
