2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
This issue occurs when the
objectstore resize-pvc operation fails with the following error:
Failed resizing the PVC: <pvc name> in namespace: rook-ceph, ROLLING BACKFailed resizing the PVC: <pvc name> in namespace: rook-ceph, ROLLING BACKTo fix this problem, take the following steps:
Run the following script manually:
#!/bin/sh ROOK_CEPH_OSD_PREPARE=$(kubectl -n rook-ceph get pods | grep rook-ceph-osd-prepare-set | awk '{print $1}') if [[ -n ${ROOK_CEPH_OSD_PREPARE} ]]; then for pod in ${ROOK_CEPH_OSD_PREPARE}; do echo "Start deleting rook ceph osd pod $pod .." kubectl -n rook-ceph delete pod $pod echo "Done" done; fi#!/bin/sh ROOK_CEPH_OSD_PREPARE=$(kubectl -n rook-ceph get pods | grep rook-ceph-osd-prepare-set | awk '{print $1}') if [[ -n ${ROOK_CEPH_OSD_PREPARE} ]]; then for pod in ${ROOK_CEPH_OSD_PREPARE}; do echo "Start deleting rook ceph osd pod $pod .." kubectl -n rook-ceph delete pod $pod echo "Done" done; fi - Rerun the
objectstore resize-pvccommand.
