- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Perform the following steps on the first server node and then on all the other nodes (both server and agent) in the cluster.
/opt/UiPathAutomationSuite folder on all the nodes. If you do not have enough space, you can either increase the capacity of this folder or remove all
the previous installer files except for cluster_config.json. You can always download the previous installer again.
df -h /opt/UiPathAutomationSuite.
To prepare for the upgrade, take the following steps:
Configuring the backup
To configure the backup, take the following steps:
Once the backup is created, continue with the following steps.
Putting the cluster in maintenance mode
Putting the cluster in maintenance mode will shut down the ingress controller and all the UiPath services, blocking all the incoming traffic to the Automation Suite cluster.
Updating Kubernetes and other infrastructure components
You must perform the infrastructure upgrade on all the nodes in the cluster.
You cannot perform this step on multiple nodes at the same time; you must wait for the upgrade to finish on each node before moving to another.
Updating Shared Components and UiPath Product Services
This step upgrades the fabric and service components running with the cluster. You must follow this steps only once from any of the server nodes.
After performing the upgrade, you can take the following additional steps:
To verify if Automation Suite is healthy, run:
kubectl get applications -n argocdkubectl get applications -n argocd -
If you experience issues with image vulnerabilities or storage consumption after performing an upgrade, delete the images from the old installer. For details, see the Troubleshooting section.
Enabling the backup post-upgrade
Before starting to upgrade the cluster, the upgrade script automatically creates a backup of the cluster and then temporarily disables it. You may want to enable the backup manually once the upgrade is done.
To enable the backup, run the following command from any server node:
# replace {version} with the version you are upgrading to
cd /opt/UiPathAutomationSuite/{version}/installer
./configureUiPathAS.sh resume-scheduled-backups# replace {version} with the version you are upgrading to
