2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
To debug Istio, you need to enable logging. To do that, perform the following steps:
Find the
istio-ingressgatewaypod by running the following command. Copy the gateway pod name. It should be something likeistio-ingressgateway-r4mbx.kubectl -n istio-system get podskubectl -n istio-system get pods -
Open the gateway Pod shell by running the following command.
kubectl exec -it -n istio-system istio-ingressgateway-r4mbx bashkubectl exec -it -n istio-system istio-ingressgateway-r4mbx bash -
Enable debug level logging by running the following command.
curl -X POST http://localhost:15000/logging?level=debugcurl -X POST http://localhost:15000/logging?level=debug -
Run the following command from a server node.
istioctl_bin=$(find /var/lib/rancher/rke2/ -name "istioctl" -type f -perm -u+x -print -quit) if [[ -n ${istioctl_bin} ]] then echo "istioctl bin found" kubectl -n istio-system get cm istio-installer-base -o go-template='{{ index .data "istio-base.yaml" }}' > istio-base.yaml kubectl -n istio-system get cm istio-installer-overlay -o go-template='{{ index .data "overlay-config.yaml" }}' > overlay-config.yaml ${istioctl_bin} -i istio-system install -y -f istio-base.yaml -f overlay-config.yaml --set meshConfig.accessLogFile=/dev/stdout --set meshConfig.accessLogEncoding=JSON else echo "istioctl bin not found" fiistioctl_bin=$(find /var/lib/rancher/rke2/ -name "istioctl" -type f -perm -u+x -print -quit) if [[ -n ${istioctl_bin} ]] then echo "istioctl bin found" kubectl -n istio-system get cm istio-installer-base -o go-template='{{ index .data "istio-base.yaml" }}' > istio-base.yaml kubectl -n istio-system get cm istio-installer-overlay -o go-template='{{ index .data "overlay-config.yaml" }}' > overlay-config.yaml ${istioctl_bin} -i istio-system install -y -f istio-base.yaml -f overlay-config.yaml --set meshConfig.accessLogFile=/dev/stdout --set meshConfig.accessLogEncoding=JSON else echo "istioctl bin not found" fi
