2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
Due to a node reboot or a restart of the Longhorn management pods, the volume occasionally fails to complete the sync loop. This causes the volume to become unready for the new workload. Due to this issue, the underlying replica runs into a faulted state and requires a salvage operation to become ready. Although Longhorn has autoSalvage enabled, sometimes the replica is not salvaged and requires manual intervention.
To verify if this issue causes the failure in the volume attachment, check if the Longhorn manager logs contain the following error:
level=info msg="All replicas are failed, set engine salvageRequested to true" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=agent0 owner=agent0 state=detached volume=pvc-49b22fef-772e-4c1f-b9eb-6bc15e7addbb
level=warning msg="Cannot auto salvage volume: no data exists" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=agent0 owner=agent0 state=detached volume=pvc-49b22fef-772e-4c1f-b9eb-6bc15e7addbb
