- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Using the monitoring stack
- Alert Runbooks
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, and Alertmanager, which are integrated within the Rancher Cluster Explorer UI.
Node failures might lead to a Kubernetes shutdown, which would disrupt Prometheus alerts. To prevent this, we recommend setting up a separate alert on the RKE2 server.
This page describes a series of monitoring scenarios. For more details, see the official Rancher documentation on using Rancher Monitoring.
When using collectors to export metrics to third-party tools, enabling application monitoring may disrupt the functionality of Automation Suite.
In the Monitoring dashboard, check the bottom pane for currently firing alerts. The following screenshots shows several currently firing alerts.
If alerts are too noisy, you can silence them. To do that, take the following steps:
It is highly recommended to set up an external receiver for alerts. This way, alerts will be pushed as they happen, instead of requiring a refresh of the Monitoring dashboard to see the latest alerts.
For details on how to send alerts to an external receiver, see the Rancher documentation on Alertmanager Receiver Configuration.
In addition to a receiver, you must configure at least one route that uses that receiver. A route defines how alerts are grouped, and which alerts are sent to the receiver. See the Rancher documentation on Alertmanager Route Configuration.
See below for an example of how the alerts will be displayed when using the Slack receiver. Clicking the link to AlertManager will take you to the AlertManager console where alerts can be silenced and there are further links to the Prometheus expression that triggered the alert. Clicking the Runbook URL will take you to this page with specific remediation instructions. These links are also present when alerts are sent to other external receivers.
On the Monitoring dashboard, click the Grafana tile. The Grafana dashboard is now displayed.
You can monitor the Istio Service Mesh via the following Grafana dashboards: Istio Mesh and Istio Workload.
Istio Mesh dashboard
This dashboard shows the overall request volume, as well as 400 and 500 error rates across the entire service mesh, for the selected time period. The data is displayed in the upper-right corner of the window. See the 4 charts across the top for this information.
It also shows the immediate Success Rate over the past minute for each individual service. Note that a Success Rate of NaN indicates the service is not currently serving traffic.
Istio Workload dashboard
This dashboard shows the traffic metrics over the time range selected in the upper-right corner of the window.
Use the selectors at the top of the dashboard to drill into specific workloads. Of particular interest is the uipath namespace.
The top section shows overall metrics, the Inbound Workloads section separates out traffic based on origin, and the Outbound Services section separates out traffic based on destination.
You can monitor persistent volumes via the Kubernetes / Persistent Volumes dashboard. You can keep track of the free and used space for each volume.
You can also check the status of each volume by clicking the PersistentVolumes item within the Storage menu of the Cluster Explorer.
To check the hardware utilization per node, you can use the Nodes dashboard. Data on the CPU, Memory, Disk, and Network is available.
You can monitor the hardware utilization for specific workloads using the Kubernetes / Compute Resources / Namespace (Workloads) dashboard. Select the uipath namespace to get the needed data.
- Select the downwards pointing arrow next to the chart title, and then select Share.
- Select the Snapshot tab, and set the Snapshot name,Expire, and Timeout.
- Select Publish to snapshot.raintank.io.
For more details, see the Grafana documentation on sharing dashboards.
For details on how to create custom persisten Grafana dashboards, see Rancher documentation.
Admin access to Grafana is not typically needed in Automation Suite clusters as dashboards are available for read access by default to anonymous users, and creating custom persistent dashboards must be created using the Kubernetes-native instructions previously linked in this document.
Nonetheless, admin access to Grafana is possible with the following instructions.
The default username and password for Grafana admin access can be retrieved as follows:
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-password}' | base64 -d && echokubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-password}' | base64 -d && echoNote that in High Availability Automation Suite clusters, there are multiple Grafana pods in order to enable uninterrupted read access in case of node failure, as well as a higher volume of read queries. This is incompatible with admin access because the pods do not share session state and logging in requires it. In order to work around this, the number of Grafana replicas must be temporarily scaled to 1 while admin access is desired. See the instructions on how to scale the number of Grafana replicas:
# scale down
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=1
# scale up
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=2# scale down
# scale up
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=2Documentation on the available metrics is here:
You can create custom alerts using a Prometheus query with a Boolean expression.
To see the status of pods, deployments, statefulsets, etc., you can use the Cluster Explorer UI. This is the same landing page as accessed after logging into the rancher-server endpoint. The homepage shows a summary, with drill downs into specific details for each resource type on the left. Note the namespace selector at the top of the page. This dashboard may also be replaced with the Lens tool.
Prometheus uses the Prometheus remote write feature to collect and export Prometheus metrics to an external system.
remote_write on an Automation Suite cluster:
- Accessing the Rancher Monitoring Dashboard
- Checking Currently Firing Alerts
- Silencing alerts
- Sending Alerts to an External Receiver
- Accessing the Grafana dashboard
- Monitoring the Service Mesh
- Istio Mesh dashboard
- Istio Workload dashboard
- Monitoring Persistent Volumes
- Monitoring hardware utilization
- Creating shareable visual snapshot of a Grafana chart
- Creating custom persistent Grafana dashboards
- Admin access to Grafana
- Querying Prometheus
- Creating custom alerts
- Monitoring Kubernetes resource status
- Exporting Prometheus Metrics to an External System
