Process Mining user guide
Viewing Process data
Display the Process data dashboard in Process Mining on Automation Suite to analyze individual cases and events at the lowest level of detail.
Introduction​
The Process data dashboard enables you to analyze Cases and/or Events on the lowest level.
Note:
Depending on the app template, Cases can be called differently, for example, Purchase order items, or Incidents.
Follow these steps to display the Process data dashboard.
  1. Select Process data in the menu on the left of the dashboard.
The Process data dashboard is displayed.
Selecting display columns​
Follow these steps to change the visible columns.
  1. Select Columns to display the list of columns.
  2. Select the columns you want to display in the selected Process data dashboard from the Visible Colums list.
    Note:
    The Case ID* column cannot be hidden. *) Depending on the app template, Case ID can be called differently,
Re-sizing the table columns​
You can change the size of the columns in the Process Data dashboard.
  1. Select the docs image icon in front of a column name.
  2. Drag to reisize the column to the desired size.
Viewing Case details​
The Details icon in front of a row enables you to view the details of a selected case. See the illustration below for an example.
The KPIs displayed on top of the Case details page are the same as the columns selected in the parent Process data page.
  • Introduction​
  • Selecting display columns​
  • Re-sizing the table columns​
  • Viewing Case details​
Connect
Stay updated
