- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- Publishing Dashboards
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Process Mining user guide
Exporting and importing transformations
Exporting transformations
Follow these steps to export the transformations from the process app.
| Steps | Action |
| 1 | Go to the Transformations panel and select the Import or export transformations icon to open the menu. |
| 2 | Select the Export transformations option. |
The transformations are that are used for the last full data run are exported and downloaded to your default download folder as a .zip file.
Importing transformations
Follow these steps to import the customized transformations in the process app.
| Step | Action |
| 1 | Go to the Transformations panel and select the Import or export transformations |
| 2 | Note: If you have added new input tables or new input fields for existing tables to the data transformations, you must upload a new dataset before importing the data transformations. Select the Import transformations option. |
The transformations are imported and and run, and the new data is displayed in the process app.
When the transformations are imported, the new transformations are automatically run. This will immediately affect the data displayed in the published process app. It is strongly recommended to test the new transformations in a separate test process app to prevent any errors. Running an erroneous transformation will result in the published app not being visible for end users.
If you select Cancel in the Import successful message dialog, the imported transformations will be available in the Data transformations editor, but the transformations are not run.
