Process Mining user guide
Data model requirements
Data model requirements and structural constraints for process apps in Process Mining on Automation Suite, including table limits and relation rules.
A data model can only be saved when it adheres to the following requirements:
  • The data model includes no more than 40 tables.
  • All tables are connected to the overall data model.
  • There are no circular relations in the data model.
  • A maximum of 15 direction changes are allowed in one relation path.
    Tip:
    A direction change is a one-to-many relation followed by a many-to-one relation, or vice versa.
Required output tables​
A data model must have a Cases, Event_log, Tags, and Due_dates table.
Note:
Depending on the app template, the Cases table has a process-specific name, for example, Purchase_order_items, or Incidents.
The Cases, Event_log, Tags, and Due_dates table must have the following output fields.
Note:
All the fields are required. However, some fields are allowed to contain only NULL values.
TableRequired output field
CasesCase_ID*
Event_logCase_ID*
Event_start
Event_end
Activity
Activity_order
Automated
Event_cost
Event_processing_time
TagsTag_ID
Case_ID*
Tag
Tag_type
Due_datesCase_ID*
Due_date
Due_date_type
Actual_date
Expected_date
On_time
Cost
Difference
*) Depending on the app template, Case_ID can be called differently, for example, Purchase_order_item_ID, or Incident_ID.
  • Required output tables​
Connect
Stay updated
