Process Mining
Last updated Jun 26, 2025
Extracting data via an ODBC connection
If you want to use data from an external data source via an ODBC connection, make sure that the required ODBC driver is installed on the server.
Note: All databases that have a 64-bit version can be accessed using an ODBC connection. The required 64-bit ODBC driver must be installed on the Process Mining server, and the server must be able to access that specific system.
