Process Mining release notes
Last updated Apr 23, 2026
2023.10.1
Addendum: December 18, 2024
Known issues
- Editing Data transformations does not work when the process app security is configured as
single_account. - Using the Data transformations editor could result in failing runs when Amazon S3 is used as storage platform. To prevent the issue, make sure to use a small dataset for the development and testing of data transformations.
Release date: December 19, 2023
We are constantly working to improve your UiPath® Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security and accessibility improvements as well as minor bug fixes to our product.
New app template available
The following app template is now available for download on the UiPath® Customer Portal:
- Oracle E-Business Suite Purchase-to-Pay
See App templates and Uploading app templates.
Bugs solved
There was an issue when running transformations from the Data transformations editor when the data for the process app was loaded using another option than Upload data in the Data source step. This is now solved.
