Process Mining
Last updated Jan 15, 2026
Configuration settings for loading input data
Settings.json
Important:
The AddRawTablePostfix and StripSpecialCharacters settings in the settings.json file are no longer supported and cannot be used anymore to switch existing process apps to the data loading behavior that was introduced in March 2023.
When uploading data, always make sure that the input data is in the required format for the app template that you use to create the process app. Refer to App Templates.
If the settings.json file of your process app still contains these settings, you can safely remove them since they are not used anymore.
Setting
Format
AddRawTablePostfix
boolean
For adding a _raw suffix to your source tables when using file uploads through the Upload data option. For example, if the file you upload is named Event_log.csv it changes to Event_log_raw.csv if this setting is set to true.
boolean
For removing special characters and replacing spaces with underscores in table names and/or field names. For example, a field called Event+end changes to Eventend.
Using existing process apps with the new data model settings
Follow these steps to use your existing process apps with the new data model settings.
  1. Download the settings.json.zip and unzip the file.
  2. Export the transformations of your process app.
  3. Add the settings.json file (if not already present) to transformations.
  4. Make sure both AddRawTablePostfix and StripSpecialCharacters are set to false.
  5. Change your input files, or transformations, such that the file names match exactly. For example, if your input transformations expect event_log_raw then your csv file should also be called event_log_raw.csv.
  6. If you are using special characters in table names or field names (for example ' ', '(' or '?'), then make sure the input transformations use the same name. For example, a field Activity category should be referred to as Activity category in your queries and not Activity_category.
  7. Import transformations and upload new data.
The transformations will be run again in the platform and the source tables will be changed accordingly.
  • Settings.json
  • Using existing process apps with the new data model settings
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
