Process Mining user guide
Introduction
DataBridgeAgent data extraction workflow for Process Mining on Automation Suite, covering source extraction and dataset preparation.
Similar to extracting data and preparing a dataset for use in a on-premises (stand-alone) Discovery Accelerator, you must extract data from the source system and create a dataset for use in Process Mining. This page describes how you can extract data from your source system for use in Process Mining using DataBridgeAgent.
DataBridgeAgent is used to extract data from the source system, and exports .tsv files. These .tsv files are loaded into the Microsoft SQL Server database using CData Sync. The following illustration shows an overview of the data flow.
Important:
Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or file to upload data.
Connect
Stay updated
