Process Mining user guide
Exporting and importing transformations
Export and import data transformations in Process Mining on Automation Suite, downloading the last full data run transformations as a ZIP file for customization.
Exporting transformations​
Follow these steps to export the transformations from the process app.
StepsAction
1Go to the Transformations panel and select the Import or export transformationsdocs image icon to open the menu.
2Select the Export transformations option.
The transformations are that are used for the last full data run are exported and downloaded to your default download folder as a .zip file.
Importing transformations​
Follow these steps to import the customized transformations in the process app.
Step
Action
1
Go to the Transformations panel and select the Import or export transformationsMenu icon icon to open the menu.
2
Note: If you have added new input tables or new input fields for existing tables to the data transformations, you must upload a new dataset before importing the data transformations.
Select the Import transformations option.
The transformations are imported and and run, and the new data is displayed in the process app.
Important:
When the transformations are imported, the new transformations are automatically run. This will immediately affect the data displayed in the published process app. It is strongly recommended to test the new transformations in a separate test process app to prevent any errors. Running an erroneous transformation will result in the published app not being visible for end users.
Note:
If you select Cancel in the Import successful message dialog, the imported transformations will be available in the Data transformations editor, but the transformations are not run.
  • Exporting transformations​
  • Importing transformations​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
