Process Mining user guide
Process mining types
Process mining model types available in Process Mining on Automation Suite, covering Directly follows, Discover, and BPMN model approaches with their trade-offs.
Directly follows graph​
Directly follows process models (adjacency graphs) focus on simplicity and readability, showing a clear and direct representation of the event log. These process models are intuitive and easy to understand, making them valuable for easily understanding the basic flow of activities. While they may not capture all the complex behaviors in the process, such as parallelism, Directly follows process models provide a useful starting point for process analysis.
The Directly follows relationship represents the order in which activities occur in a process. It is based on event logs that contain records of activities performed during the execution of a process. By analyzing the event logs, Process Mining techniques can identify which activities are typically executed one after another. Between these two activities, an edge is defined as A➝B.
If, for example, paths A→B and C→D in a process can be performed in parallel, the activities of the two paths can occur in the event log in any order. In the "directly follows graph" approach, these events will not be considered to run in parallel, and the resulting process flow can be the following: A➝C➝B➝D.
A Discover process model or a BPMN process model however will take parallel structures into account.
Discover process model​
Discovering a process model allows you to have a better understanding of your process structure. By analyzing the whole process (the whole event log) with advanced process mining techniques, activities that happen in parallel, are part of a decision, or are part of a more complex loop are automatically discovered. These relationships are called the process semantics.
The following table describes the process semantic types used in discover process models.
Semantic node typeDescriptionVisual representation
Parallel gateway (AND)Represents two or more branches that happen in parallel.Parallel gateway (AND)
Exclusive choice gateway (XOR)Represents an exclusive choice (decision point) between two or more branches.Exclusive choice gateway (XOR)
Loop gatewayRepresents a repeatable sub-process with one loop body path and one or more rework paths.Loop gateway
Import BPMN model​
Select Import BPMN model if you want to import your own BPMN 2.0 model and use it as a process mining type for your process app.
Note:
With the BPMN model, advanced process algorithms will map your event log data on top of the BPMN model, allowing you to analyze how the BPMN model and your data relate.
  1. Drag and drop the .bpmn file that contains the BPMN 2.0 model you want to import.
When the file is successfully imported, the Next button will be enabled.
Tip:
If you want to use a different BPMN model after you created the process app, you can import a BPMN model in Process models.
BPMN model requirements​
The following sections describe the requirements to successfully import a BPMN 2.0 model for use in Process Mining.
General requirements for the BPMN model​
  • The BPMN must adhere to the BPMN 2.0 standard.
  • The BPMN must contain a single process definition.
  • The BPMN can only contain supported elements.
  • All nodes in the BPMN should have an id.
  • The BPMN model should contain no more than 999 nodes.
Supported BPMN elements​
The following BPMN elements ares supported:
  • Start events
  • End events
  • Tasks
  • Exclusive choice gateways
  • Inclusive choice gateways
  • Parallel gateways
  • Sequence flows
Task and flow requirements​
RequirementExample
A start event must be defined, and there can only be one start event.
An end event must be defined, and there can only be one end event.
At least one activity task must be defined.
There must be at least two sequence flows defined for the BMPM model.
The tasks must have unique labels.
All sequence flows must have a source and a target.
Each task must have a single incoming, and a single outgoing sequence flow.
The start event only has a single outgoing edge.
The end event only has a single incoming edge.
All nodes and sequence flows in the BPMN are connected in a single model.
Gateway requirements​
The gateways in the BPMN must form pairs. Each pair has an opening gateway, which splits the process flow into multiple process flows. Each pair has a closing gateway, which joins the split process flows into a single flow. This structure is called a block. The flows inside a block may contain other, nested blocks. However, the only flows to enter and exit the flows within a block, are via the split and join gateways.
The following illustration shows an example of a BPMN model with gateway pairs, forming blocks. The blocks are highlighted.
RequirementExample
Each gateway is either a split or a join gateway.
A split gateway has a single incoming edge, and at least 2 outgoing edges.Split gateway
A join gateway has at least 2 incoming edges, and a single outgoing edge.Join gateway
For every split gateway, there is a corresponding join gateway of the same type, and vice versa.
Every split-join gateway pair and the elements between them are a single-entry-single-exit component: a model component that has only a single entry edge and a single exit edge.
Each path from a split gateway its corresponding join gateway must also be a single-entry-single-exit.
There cannot be any direct sequence flows between corresponding splitting and joining parallel gateways.
Every exclusive choice split-join gateway pair that describes a loop flow to a previous point in the process cannot have an empty main path and an empty redo path, as this allows for indefinite looping without a task being executed.
Connect
Stay updated
