Process Mining user guide
Process Mining configuration checklist
Configuration checklist for verifying that Process Mining is working correctly after installation and enablement on an Automation Suite environment.
Introduction​
After installing and enabling Process Mining on your on-premises (Automation Suite) environment, make sure to check the list present in this guide that evaluates if Process Mining is working properly.
Process Mining portal​
Managing access​
Loading data​
Customizing apps​
Working with process apps​
  • Introduction​
  • Process Mining portal​
  • Managing access​
  • Apps​
  • Loading data​
  • Customizing apps​
  • Working with process apps​
Connect
Stay updated
