Process Mining user guide
- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Adding input tables
- Deleting input tables
- Managing input data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Delete input tables from a process app in Process Mining on Automation Suite when the data is no longer needed.
Note:
You can delete input tables that you do not need anymore. Deleting an input table removes the data for your process app. If you want to use the data in your process app at a later stage, you must re-upload the input table.
Follow these steps to delete an input table from the Input data list.
- Locate the input table you want to delete.
- Select the context menu icon and select Delete. A confirmation message is displayed.
- Select Delete to delete the input table.
The input table is no longer available in the Tables section.
