Process Mining
Last updated Jan 26, 2026
Managing input data
You can configure the input tables directly from Data Transformations to ensure your input data meets the requirements for your process app. The Manage input data settings option allows you to easily configure existing input tables or create new input tables from newly uploaded files.
Follow these steps to manage input data settings.
  1. In the Input section, locate the Tables folder.
  2. Locate the table for which you want to manage the files and select context menu icon to open the Edit table panel for the selected table.
The Tables page is displayed, showing the source tables that are already present for your process app.
Mapping and configuring input tables
When you upload one or more files, a new table is automatically added in the Source tables section for each uploaded file and a corresponding input table is created in the Target tables section. By default, the file name of the uploaded file is used as the name of the tables. A warning message is displayed indicating the table needs configuration before data can be uploaded for the table.
Mapping input tables
Your input data must meet the data model defined for your app. If needed, you can map a Source table to a different Target table.
Configuring input tables
The settings for the target input table are automatically detected and you just need to check them.
Follow these steps to edit the settings for an input table.
  1. Locate the table you want to configure and select the Edit table icon to open the Edit table panel for the selected table.
  2. Edit the settings as desired and select Save.
The following table describes the table settings.
SettingDescription
Table nameThe name of the input table in Data transformations.
Mandatory
Option to define the table as mandatory.
If TRUE, the table will be required later when publishing or importing the process app. If the table is not uploaded then, an error is thrown. If FALSE, the table is considered as Optional., when publishing or importing the app. If the table is not uploaded then, an empty table will be created such that subsequent SQL queries will not fail.
AutodetectEnables you to identify field types in the input file and automatically apply the detected field types to the corresponding fields in the target table.
EncodingThe encoding used in the file.
DelimiterThe delimiter separating the different fields.
Line endingThe character that is used to denote the end of a line and the start of a new one.
Quote characterThe quote character used in case fields are wrapped within quotes.
Escape characterThe escape character used to correctly interpret characters that would otherwise be treated as special control characters (such as quotes or delimiters).
Note: By default, the selected Quote character is used as the escape character. Alternatively, you can select the backslash (\) as the escape character.
Removing a source file
If you accidentally select a source file while uploading source data, you can remove it from the Input data screen.
Note: A source file can only be removed if no data has been uploaded for it.
Follow these steps to remove a source file.
  1. Locate the source file you want to remove in the Source tables list.
  2. Hover your mouse over the table, and select Remove file.
The input file is removed.
Mapping and configuring input fields
When you finished configuring the input tables, you can map and configure the input fields for the tables.
  1. Select Next in the Tables page. The Fields page is displayed.
For each table the fields from the source file are automatically detected and mapped to the corresponding fields in the target table.
Mapping input fields
Your input data must meet the data model defined for your app. If needed, you can map a Source field to a different Target field.
Configuring input fields
The settings for the target input fields are automatically detected and you just need to check them.
Follow these steps to edit the settings for an input field.
  1. Locate the field you want to configure and select the Edit field icon to open the Edit field panel for the selected field.
SettingDescription
NameThe name of the field.
Note: Name is a mandatory field.
TypeThe data type of the field.
  • Text
  • Integer
  • Decimal
  • Boolean
  • Date
  • Datetime
Note: Depending on field type you must specify parse settings to configure the field.
Mandatory
Option to define the field as mandatory.
If selected, the field is required when publishing or importing the process app. An error is thrown then if the field is missing. If not selected, the field is considered optional. When it is missing, the field will be added with NULL values, such that subsequent SQL queries will not fail.
UniqueOption to define the field value have a distinct or unique value for each record.
Not NULLOption to define that the field must have a value for each record. The field cannot be left empty or filled with a NULL value.
Parse settings for field types
The following table describes the available parse settings for the different field types.
Field typeParse settings
IntegerThousand separator
  • None
  • Dot (.)
  • Comma (,)
Decimal
  • Decimal separator
    • Dot (.)
    • Comma (,)
  • Thousand separator
    • None
    • Dot (.)
    • Comma (,)
Boolean
  • True value:
    TRUE or 1
  • False value
    FALSE or 0
Note: True value and False value are mandatory settings and must be different.
DateDate format (Check out Example parse settings for Date formats).
DatetimeDate time format Date format (Check out Example parse settings for Datetime formats.)
FormatExample
yyyy-mm-dd
2025-04-05
2025-4-5
mm/dd/yy
04/05/25
4/5/25
mm-dd-yyyy
04-05-2025
4-5-2025
dd-mm-yyyy
05-04-2025
5-4-2025
FormatExample
yyyy-mm-dd hh:mm:ss
2025-04-05 14:30:45
2025-4-5 14:30:45
yyyy-mm-dd hh:mm:ss[.nnn]
2025-04-05 14:30:45.123
2025-4-5 14:30:45.123
yyyy-mm-ddThh:mm:ss[.nnn]
2025-04-05T14:30:45.123
2025-4-5T14:30:45.123
mm/dd/yy hh:mm:ss AM/PM
04/05/25 02:30:45 PM
4/5/25 02:30:45 PM
mm-dd-yyyy hh:mm:ss[.nnn]
04-05-2025 14:30:45.123
4-5-2025 14:30:45.123
04-05-2025 14:30:45
4-5-2025 14:30:45
dd-mm-yyyy hh:mm:ss[.nnn]
05-04-2025 14:30:45.123
5-4-2025 14:30:45.123
05-04-2025 14:30:45
5-4-2025 14:30:45
yyyy-mm-ddThh:mm:ss[.nnn]+00:00*
2025-04-05T14:30:45.123+02:00
2025-04-05T14:30:45-03:00
2025-04-05T14:30:45
2025-4-5T14:30:45.123+02:00
2025-4-5T14:30:45-03:00
2025-4-5T14:30:45Z
yyyy-mm-ddThh:mm:ss+00:00*
2025-04-05T14:30:45+02:00
2025-04-05T14:30:45
2025-4-5T14:30:45Z
dd/mm/yyyy hh:mm:ss[.nnn]
05/04/2025 14:30:45.123
5/4/2025 14:30:45.123
*) Timestamps that include time zone information are automatically converted to UTC during data ingestion.
Adjusting existing process apps to utilize the Manage input data screen
Introduction
Note:
Although existing process apps remain fully functional, you can adjust process apps to utilize the Manage input data screen in Process Mining. With the Manage input data screen, you can easily add new input tables and input fields. Therefore, it is recommended to adjust process apps for which the structure of the input data is subject to change. If you do not anticipate many changes to the structure of the input data, you might want to consider not adjusting the app.
If you want to start using the Manage input data screen to load the tables and fields for an existing process app, you need to manually perform the steps described on this page.
Prerequisites
Before you start adjusting your app:
  1. Make sure that all changes to the process app are published.
  2. Export or clone the process app to save a backup.
Steps
Tip:
The input queries are the SQL files that refer to a table defined in the sources section. These models tend to be located in the folder 1_input.
Follow these steps for each of the input queries.
  1. Make sure that the input SQL file only contains renames and type casts. Move other logic (filtering, derived columns, etc.) to subsequent SQL files.
    The following illustration shows an example Event_log_input.sql file that only contains renames and type casts.
  2. Go to Manage input data and adjust the field properties for each field. Refer to Mapping and configuring input fields for details.
    1. Set the data type and renames using the Manage input data settings option in Data transformations.
    2. Check the Field attributes (Mandatory, Unique, not NULL) in the Field properties panel and make sure they are set correctly.
  3. Check all the SQL files for references to the input table: {{ ref('table_name') }}, and update these references to use the new table:
    Replace every occurence of {{ ref('table_name') }} with {{ source('sources', 'source_table_name') }}. For example: replace {{ ref('Event_log_input') }} which pointed to your SQL files with {{ source('sources', 'Event_log_raw') }} to point directly at the source table.
    Note:
    These references can occur in any SQL file.
  4. Since the original input SQL file is not used anymore, you can now safely delete it.
Important:
If your transformations contain a format setting that is not yet available in Manage input data settings, the type casting should remain in the dbt transformations. For example, SAP dates are not available (YYYYMMDD).
Troubleshooting
Question
The file that I uploaded before cannot be correctly loaded.
Possible solution
Inspect the encoding and line endings of the files to check if they match with the table setttings. Refer to Mapping and configuring input tables for more information.
© 2005-2026 UiPath. All rights reserved.
