Process Mining user guide
Activity Configuration: Defining activity order
Activity_order field reference for Process Mining on Automation Suite, used to break ties when two events share the same timestamp in SQL transformations.
The Activity_order field is used as a tie breaker when two events are happening on the same timestamp.
Option 1: SQL configuration​
The following code shows an example of configuring Activity_order with a SQL CASE statement:
    case
            when tableA."Activity" = 'ActivityA'
                then 1
            when tableA."Activity" = 'ActivityB'
                then 2
            when tableA."Activity" = 'ActivityC'
                then 3
            when tableA."Activity" = 'ActivityD'
                then 4
    end as "Activity_order"
    case
                then 1
                then 2
                then 3
                then 4
Option 2: CSV seeds file​
Instead of using a SQL CASE statement, you can define Activity_order using the activity_configuration.csv file .
The following illustration shows an example activity_configuration.csv file:
Recommendations​
Most UiPath app templates come with predefined fields for activity configuration, which you can adapt to your specific business requirements. If predefined fields are unavailable or insufficient, you can always create custom fields using either SQL or the activity_configuration.csv seeds file, as outlined.
  • Option 1: SQL configuration​
  • Option 2: CSV seeds file​
  • Recommendations​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
