- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Adding input tables
- Deleting input tables
- Defining new input tables
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Process Mining user guide
Last updated Apr 23, 2026
Note:
Deleting an input table removes the data for your process app. If you want to use the data in your process app at a later stage, you must re-upload the input table.
Follow these steps to delete an input table from the Input data list.
- Locate the input table you want to delete.
- Select the Remove table
table icon. A confirmation message is displayed. - Select Delete to delete the input table.
