Process Mining user guide
Last updated Apr 23, 2026
Automation manager
Introduction
Automation manager enables you to manage automations connected to Process Mining. With Automation manager you can select Orchestrator queues to be used for automations triggered by business users from the process app.
Automation manager is integrated in the dashboard editor. Refer toWorking with the dashboard editor for details.
Important:
Publish your process app after adding or editing an automation to make the automation available to business users. Refer to Publishing Dashboards. Also make sure that business users have the proper access rights in Orchestrator to access the queue. Refer to Default roles for details.
Manually triggered automations and automatically triggered automations
There are two different types of automations that can be triggered from a process app.
  1. Manually triggered automations are initiated by business users from the process app dashboards.
  2. Automatically triggered automations are initiated when predefined conditions, determined by tags, are met during the data run for the process app.
    Note:
    Manual triggers can be done from both the development and published app. Automatic triggers are only applied when loading data on a published app.
When you select the Manual trigger type for the automation, business users can trigger the automation from the published process app. The Trigger an automation option is available on most dashboards and charts. The following illustration shows an example.
Trigger an automation option on a chart
When the user has selected objects that are candidate for automation, the Trigger an automation option can be selected to enter the input data for the automation.The following illustration shows an example.
Trigger an automation panel
For every case that is selected, a Queue item is created in the Orchestrator queue that will trigger the automation defined in Studio.
Queue items in the Orchestrator queue
Refer to Triggering an automation from a process app for details on how to trigger an automation from a published process app.
Automated triggers can trigger automations when specific events occur within the process. This allows for immediate attention to a case for enhanced efficiency and streamlined workflows.
When you select the Automatic trigger type for the automation, the automation is triggered automatically when the trigger conditions have met. The trigger conditions are determined by tags that are evaluated any time data for the process app is loaded. Each case that meets the conditions creates a Queue item in the Orchestrator queue, which initiates the automation defined in Studio.
Opening Automation manager
Select the Automation manager button in the upper right corner of the dashboard editor to open Automation Manager. The Automation manager page is displayed, showing the automations defined for your process app.
Building an automation
You can start building an automation in Studio directly from Automation manager.
  1. In Process Mining open the process app for which you want to enable automation integration in the Dashboard editor. Refer to Working with the dashboard editor for details.
  2. In the Dashboard editor, select the Automation manager option to open the Automation manager.
  3. Select Build automation to open Studio. Refer to Automation manager for details.
Adding an automation
Follow these steps to add an automation for your process app:
  1. In Automation manager, select + Connect automation. The Add queue page is displayed, showing all Orchestrator queues that have Specific data JSON schema. Refer toSetting up Automation integration.
  2. Select the queue you want to use for the automation. The required input fields for the queue are displayed in the Properties panel.
    Add queue dialog
  3. Select the type of trigger for the automation from the Trigger list box.
  4. Map the queue input fields to the appropriate data fields of your process app.
    Important:
    Check out the data type of the queue input fields defined in the Specific data JSON schema and make sure to map the input fields to a Process Mining data field with the correct input type. Check out App Templates.
    Field mapping options
Instead of mapping to a specific data field, you can select the Busines user input option for a text input field. This enables business users to enter a free text when triggering an automation.
Note:
The Business user input option is only applicable to Manual triggers.
  1. Enter the Maximum number of cases sent at once to limit the number of cases that can be sent to Orchestrator.
    Note:
    As an analyst, it is important to consider limiting the number of cases a business user can send to Orchestrator based on the specific use case. By default, the system allows 50 cases to be sent to the queue, but the range can be adjusted from 1 to 1000, providing flexibility for different scenarios.
    Add queue
  2. Select the type of the trigger for the automation from the Trigger list box.
    • If you want to configure an Automatic trigger for an automation, add the fields and select the field values to define one or more trigger conditions.
      Note:
      Only field of type nominal can be used for trigger conditions.
A case that meets a condition when the filter is evaluated will be sent to Orchestrator. :::note Each trigger condition is evaluated separately. For example, Case 001 has tags A and B. When you have set the trigger conditions for both A and B, this case will be sent to Orchestrator twice (one based on condition A, and one based on condition B). ::: 7. Select Save.
Editing an automation
Follow these steps to edit an automation.
  1. In Automation manager, locate the automation you want to edit on the list of automations and select Edit settings icon.
  2. Change the settings as desired.
  3. Select Save.
Refreshing the queue
Important:
If any changes are made to the Orchestrator queue, you need to refresh the queue in Process Mining. For example, when the Specific data JSON schema has changed, or when the name or description of the queue was edited in Orchestrator. To refresh the queue in Process Mining, you edit the automation in Automation manager.
Follow these steps to refresh the queue for an automation.
  1. Locate the automation for which you want to refresh the queue and select Edit settings icon.
  2. Select the Refresh button at the top of the properties panel.
  3. Select Save.
Removing an automation
Follow these steps to remove an automation.
  1. Locate the automation you want to remove from the automations list and select Delete icon.
The automation is removed from the list of automations.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
