- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Transforming data
 - Customizing dashboards
 - Publishing Dashboards
 - App templates
 - Notifications
 - Additional resources
Process Mining
Refer to the official Theobald Software documentation for more information on installing and updating Theobald Xtract Universal and customizing the function module for table extraction in SAP.
Z_THEO_READ_TABLE-transport1 that is to be installed in SAP.
            You can use the following link to download the custom module: Z_THEO_READ_TABLE-transport1.zip.
Z_THEO_READ_TABLE-transport1.zip file will always be included when you download Xtract Universal.
               Follow these steps to set up Theobald Xtract Universal.
Download the latest trial version of Theobald Xtract Universal from our website, check out Download Trial Version. Install Theobald Xtract Universal on a Windows Server / Virtual Machine.
On the server where Theobald Xtract Universal is installed, check if the network access to your SAP system is open, check out SAP TCP/IP Ports.
Grant SAP user rights to access the SAP instance.
Important:Use the SAP profile for Table. Check out Authority Objects - SAP User Rights for Table.
Make sure that the user has Display access for the process-specific tables of the app template that are used for extraction.
                  Add the
Z_THEO_READ_TABLEFunction Module in SAP using the SAP transport file. -
Configure Theobald Xtract Universal for the required app template(s). Check out App Templates. If you encounter any issues, contact UiPath® Customer Support for help.
Steps 2-4 will require validation from your SAP team.
Uploading data to Process Mining (Automation Suite) requires access to the SQL Server database location to which the extracted data needs to be uploaded. To set up a SQL Server destination connection you need the following setup parameters to authenticate access to the SQL Server database location.
ServerDatabaseSchemaRole
